turboram wrote:but it raises low end timing.
RCCUMMINS89 wrote:BC... why won't the adj. spacer work?
turboram wrote:Wow case pressure effects pump volume BIG time, even worse on 14mm pump the 14mm starts loosing at 2500rpm with stock case pressure setting . Duel feed will be tryed soon .
I did learn that tapping in the case pressure plug makes a huge difference on fuel delivery , but it raises low end timing.
