RCCUMMINS89 wrote:Bring up a good point.
Not that we ever use that much power towing. But once I started making over 325-350 rwhp... but cooling system can't keep up. Meaning by the time I wot it from 20-80 (not very long time wise) my coolant temp will rise from the 2nd mark to passed the 3rd mark. I can reach the hot mark in about 10 - 15 seconds at wot.
dunes450r wrote:RCCUMMINS89 wrote:Bring up a good point.
i have a very hard time believing you can heat soak your cooling system in 10-15 seconds. heat won't conduct that fast through the cylinder walls to be absorbed by water and get pumped around in that amount of time.
the factory gauge is not consistent or reliable on temps either. i've seen actual temps fluctuate as much as 30* for the exact same mark on the factory gauge. you need to put in an actual temp gauge and then get back to us.
BILTIT wrote:yes the lpplp is on the side of the engine but the stock one is a weak diaphragm pump, the piston pump is an upgrade (from a 2nd gen but with modified spring pressure).
Sutter1stgen wrote:John was running conservative timing, pods, and the compounds we discussed. His egts were scary low. But he complained that long grades would heat soak his cooling system no problem. Hell even jqmile mentioned it with his p pumper after he installed twins. Its like you go from worrying about one thing getting hot to the other.
At the end of a quarter mile pass I can bring my temps up pretty quick, and high (14.50 sec). So I can see someone towing, which no doubt applies more of a strain and load on the engine doing the same in less time, possibly even with far more extreme outcomes. I run a teefer advanced so I know it's keeping the heat in there a bit better.
Well enough of the points getting across, compounds are cool, and they make driving a pleasure no matter the conditions and hp range.
