Injector data
Re: Injector data
Postby RCCUMMINS89 » Thu May 16, 2013 10:51 am
Correction...............
Yes, the 0 432 131 837 p/n is a 4 hole injector............ I was thinking of another p/n. :roll:
Re: Injector data
Postby cougar » Thu May 16, 2013 12:51 pm
jkidd wrote:Good info here.
0432131837 are 4x.013... are you sure yours are 5x.012
For a little more info on our 7 hole injectors
we have 7x.0105 with slight extrude hone and flow matched with liquid at 100BAR (about 1500 psi) instead of air at 50psi as is common in the industry. They are hotter than our 5x.013
out 7x.012 have some needle work, extrude hone, flow matched with liquid at 100BAR (about 1500 psi) instead of air at 50psi as is common in the industry and no edge filters. These are very close to 5x.016 in flow.
Aftermarket bodies are also available so there is no core charge if you already have performance injectors you want to keep, stock injectors or have 9mm that no one will give you credit for.
Yep, cleaned them up and pin gauged them. Got them off of ebay, so it wouldn't surprise if someone put them in the wrong boxes.
Haven't been able to run the new injectors any more than to make sure there were no leaks. Cranked up the star wheel a bit. Maybe tomorrow I'll hit the road and give them a shake down.
01 2500 "the work truck".
cougar
