RCCUMMINS89 wrote:
I'll be able to tell a lot by boost/egt numbers. But then again, it's becoming an opinion and memory.
dazedandconfused wrote:You need the isspro gauges and data logger system for test like this.
RCCUMMINS89 wrote:dazedandconfused wrote:You need the isspro gauges and data logger system for test like this.
A good start would be injectors that are actually equal to each other...........maybe we'll see what develops
Tacoclaw wrote:Yup, I demand a 3-angle Go-Pro throughout every test, one watching gauges, one watching exhaust, and one watching you watching the gauges to make sure you're not picking your nose. I also demand multiple dyno runs with various tuning setups repeated for each set of injectors.
Ellis said he'd cover the expenses.
ellis93 wrote:Tacoclaw wrote:Yup, I demand a 3-angle Go-Pro throughout every test, one watching gauges, one watching exhaust, and one watching you watching the gauges to make sure you're not picking your nose. I also demand multiple dyno runs with various tuning setups repeated for each set of injectors.
Yep using Levi's checking acount and every thing
Tacoclaw wrote:ellis93 wrote:Tacoclaw wrote:Yup, I demand a 3-angle Go-Pro throughout every test, one watching gauges, one watching exhaust, and one watching you watching the gauges to make sure you're not picking your nose. I also demand multiple dyno runs with various tuning setups repeated for each set of injectors.
Hmmm... Better make that 3 disposable cameras and however many trips down a straight stretch of road 5 gallons of diesel will get you.
