?? on bosch 190's and ?? on extrude honing
Re: ?? on bosch 190's and ?? on extrude honing
Postby brandonmgreer » Sat Sep 28, 2013 3:35 pm
Well, this farm town mentality is the same as everywhere else... younguns wanna know if it rolls coal. they dont care about anything else.
I built my duramax for mileage, and it runs good enough to back all the dodge cr guys off, so with the influx of first and second gens popping up, and the shops around here not knowing squat about mechanical injection, I want to build something new to shut em up.
Plus its awesome when you can get in that hole on the freeway and the guy in the king ranch ford cant stand that turd just passed him!
White/black 92 D250 manual conversion, Pump tweaking is about it right now...
95 CCLB 4X4 5 speed being but back together from a wreck
99 Kenworth W900 flat top, Tuned 500 Detroit, BW 75mm 1.32A/R, 5915 injectors, 13 speed, 3.55's
brandonmgreer
Postby RCCUMMINS89 » Sat Sep 28, 2013 6:04 pm
Oh, I hear ya.
And our lightweight trucks fly with not much power.
Anything larger than about a 60-65lpm injector and things just don't run right. There are ways to overcome it, just takes a little know how and TUNING.
400rwhp can be made with 50lpm sticks...........anything bigger than about 55-60lpm and drivability becomes a loss for each hp one gains.
Postby brandonmgreer » Sat Sep 28, 2013 10:19 pm
Will a 55-60 lph stick push a set of twins effectively? And what does that translate do, a 5x13ish? I figure to go as big as i can and open them up if need be.
There will prolly be a small hit of dope and water meth in the mix as well. ;-)
brandonmgreer
Postby RCCUMMINS89 » Sun Sep 29, 2013 7:56 pm
Guys push twins with 55lpm sticks.
5x13 sticks are a good match if one wants to open them up later (extrude hone). 5x13 can be opened up to about 72lpm later on.........which is about the same size as ddp comp injectors.
Postby brandonmgreer » Mon Sep 30, 2013 9:41 am
Good to know. I guess its time to start shopping and stacking parts... all it takes is money, right?
brandonmgreer
Postby RCCUMMINS89 » Mon Sep 30, 2013 9:49 am
I'm running a 5x14.5 injector that we opened up to 77lpm.
