DTanklage wrote:the vane pump supplys the case (20-150?) (60-120?)
(see why i keep saying we need to install case press gage?)
seeker1056 wrote:
In any other kinda race engine you figure out the fuel requirements in lbs per hour per projected hp, or gallons per minute if you will.
seeker1056 wrote:
So if you only need by calculation 3/4 of a gallon in one minute, why would you be trying to be supplying 3 or 4 gallons per minute and bypassing most of it back to the tank?
seeker1056 wrote:
Bigger line is NOT always better, and for our needs 3/4 inch would be rediculous in the extreme, if you could even keep pressure up in it.
seeker1056 wrote:
If you do the calculation on 3/8" line, and then use two as suggested, you have more than the ideal setup for volume and pressure.
seeker1056 wrote:
does the rotary pump need the proposed high fuel bypass to cool the pump at high demand
seeker1056 wrote:
If you remove the restriction in the fuel inlet fitting at the rotary pump ie enlarge it from its approximatley 3/16" (size of the inverted flare) to almost 3/8" to match the supply line you would more than double fuel flow and should be able to supply more than enough fuel for 700 or so hp without all the convoluted dual fuel supply system stuff.
seeker1056 wrote:
Or am I missing something here
JD730 wrote:
Around 40 I think, maybe 50, I'm not completely sure. I wasn't in the cab very long, had other problems to deal with.
seeker1056 wrote:hmmm
I think maybe this is going a little backwards
Fact is 1/2 inch is almost too big for the actual volumes required, from what I see in the posts from people who are actually makin big hp numbers.
Why - It takes one hell of a pump to make several gallons per minute flow and keep line pressure up.If you do the calculation on 3/8" line, and then use two as suggested, you have more than the ideal setup for volume and pressure.
Which leads me to my next question - what is the problem that makes one feel they need to feed both ends of the case?
Or am I missing something here - does the rotary pump need the proposed high fuel bypass to cool the pump at high demand, or are you all sayin the pump is cavitating and losing pressure and these dual line systems are the bandaid?
Thoughts please
DTanklage wrote:pps - whats wrong with your new injectors?
