how does the m&h timing spacer work?
Re: how does the m&h timing spacer work?
Postby RCCUMMINS89 » Tue Nov 11, 2014 9:54 pm
Might be easier to explain over the phone. 208 215 5659
Postby Tacoclaw » Wed Nov 12, 2014 5:28 am
Your IP has 2 barrels inside of it, one inside the other. The inner barrel has one hole in the side, the outer barrel has 6, one for each cylinder. As the inner barrel spins, and the outer stays stationary, it's hole lines up with a hole in the outer piece. When the two holes line up, that cylinder gets fuel.
Advancement is done by rotating the outer barrel to match up the holes sooner, the spacer allows it to rotate a little farther.
Postby RCCUMMINS89 » Wed Nov 12, 2014 7:35 am
Taco........um, what?
Postby Tacoclaw » Wed Nov 12, 2014 8:19 am
I would repeat it but it's right up there. Just read it again.
Postby Tacoclaw » Wed Nov 12, 2014 8:45 am
Just think, in the amount of time it took you to read my example and question it, you could have just typed your own. :roll:
Here, kids.
Postby dpuckett » Sun Nov 23, 2014 11:04 am
So, when you put the spacer on the left, under the spring, it will allow more timing advance at higher rpms. In stock form, it is limited by the block plate/ksb assembly, and can only go so far.
