A/R TO cm2 CONVERSION ??
Postby ford69557ci » Tue Nov 27, 2007 5:31 pm
ATS has somebody make a smaller housin for it because an aroura 5k is just a k31 with a non gated smaller housing
ford69557ci
Postby DLittle » Tue Nov 27, 2007 5:58 pm
92 D/UNIT wrote:thanks Dana, so basically about 25 cm2 exh housing. mine is the garrett version of the k31. do you think it matters? was that for the 1.28 a/r?
Here's a link with some of the garrett part #'s
http://www.citydiesel.net/hot-rod-detro ... p-216.html
Dana
1992 W250 auto, 290 k, stock for now SOLD
1973 W100 SWB, D70,D60, 5.9 Twin Turbo SOLD
1993 W250 193k, Auto, TOTALED 10/30/2009
DLittle
Postby ford69557ci » Tue Nov 27, 2007 6:03 pm
same one i have alot of the higher horse 60 series came with that turbo factory that seems to be an upgrade for the lower horse ones
ford69557ci
Postby 92 D/UNIT » Fri Nov 30, 2007 10:13 pm
maybe some body can give me some input by visually looking and telling me if the exh housing looks big or if its ok.
Brian 92 D 250 250K, A518, pump mods, BHAF, 4X15s, 4" turbo back dual exh, 3200 spring, HTB2 62/12.
SOLD 92 w250 ex cab, 5 spd, 3.54, 320,000, WH1E 14, Fuel pin, pods,shortened 4200 gs, Bhaf, 4" turbo back
388/886
92 D/UNIT
Postby ford69557ci » Sat Dec 01, 2007 8:32 am
looks like ythe one that II uses on thier towing twins
ford69557ci
Postby bgilbert » Mon Dec 03, 2007 9:18 am
There's a local truck puller that uses that same charger as a big single. Makes about 2psi at 4000rpm no load then about 60psi under load. I'd say it would be a good street combo. Not quite as big as a 3"/3.4" 1.32 ar s400, but you probly wouldn't need that much.
Bill Gilbert
bgilbert
Postby ford69557ci » Mon Dec 03, 2007 5:17 pm
yes the k31 is a little smaller than the s400 but it would be good for faster spool and daily driving.
ford69557ci
