Tuning an he351/ht60
Re: Tuning an he351/ht60
Postby josh_6bt » Wed Aug 20, 2014 9:28 am
Yes that's my game plan for tonight after work
1992 W250 EC, 5 speed, 3.54s, 175hp p-pump, timed @ 16.5, #100 fuel plate, 4k GSK, 5x14, .024 DV, head studs, 60lb VS, 4" exhaust, BHAF, cooler tubz.
josh_6bt
Postby RCCUMMINS89 » Wed Aug 20, 2014 10:12 am
I agree... probably a boost leak.
Postby josh_6bt » Wed Aug 20, 2014 8:46 pm
Found one leak. Was able to build 50psi with the wastegate line disconnected.
I'm thinking the gate is creeping open so I'm gonna put my spring style gate on and go from there. If nothing else I'll swap put my 7x10s for 5x16s
josh_6bt
Postby 93flatbed » Fri Aug 22, 2014 7:36 pm
I have no real world experience, but I've read that spring gates are not the best in a compound set up.
I agree boost leak sounds like most of your issues.
93flatbed
Postby Tacoclaw » Fri Aug 22, 2014 8:39 pm
Spring 'gates are the go-to in a compound setup, IMO, the main factor in the is drive pressure, so if you can reliably control it you're golden.
Honestly, drive pressure is the main focus on any boosted application, it's not boost that blows he'd gaskets, it's cylinder pressure. Sure you can push in 40psi, but what is a portion of the remains of the last combustion cycle didn't make it out? Between whatever pressures are residuals and the timing you're running, who knows what the cylinder is fighting against.
Boost pressure is a small overall number in the overall working pressures of an engine, so I've never paid them much mind.
Postby josh_6bt » Fri Aug 22, 2014 8:51 pm
Installed my spring gate with difference in power. Clears up at high rpm and egts top out at 1300, so gonna get bigger nozzles (5x16s). One thing tho it has a bit of low boost smoke and my star wheel is pretty tight. How can I get rid of this? I know it's newbie question but it bugs me. I jumped my timing 1 tooth plus a 1/16 also. Just would like smooth clean power and no lag.
josh_6bt
Postby oldestof11 » Sat Aug 23, 2014 9:25 am
I think a needle valve in the AFC line may help to slow the low boost fueling.
