JQmile wrote:Thanks for all your interest! "Budget" and "Simple" are the two main goals of the project. This means we're sticking with the 727. Got a tranny guy that's going to be doing a regular hi-po rebuild on the 727 (good clutches and bands) and picked up a converter from Dave Goerend. Stuff anyone can do. We are going to spray it (nitrous) which a lot of people won't like, but hey, it's my truckA fast reliable truck is what we're shooting for, on a budget. The big key is weight. The truck only weighs 4850. I figure if a 7000# Duramax can run 11.90s with 700rwhp, then I'll only need 500rwhp to do it. Don't want to cage it, so 500rwhp with nitrous is what we're shooting for. Shouldn't be too hard. Going to max out the 12 first, then going with a 14mm and a fuel system. Maybe try to fab a set of twins with a HT3B...dunno how far we'll go yet....I'll keep you guys updated, but the trans won't be in for a month or so, so don't expect things to move too fast.
I would recommend a Cheetah manual shift valve body, makes one vary vary firm 1-2 shift and 2-3 hit hard too.
This eliminate having to time the revers band release(what aloes deceleration or hold back when letting of the go peddle when in L1)with the 2nt gear (band) engaging
NOTE: If this truck is to tow any thing or go off roading............I would not recommend the manuals shift valve body.
Going down hill with your foot off the go peddle, in L1 will be just like you in neutral............until you rev the eng back up to speed. I'm not doing a vary good job of explaining this..................its like you put the shifter into N every time you let of the go peddle and when you step on it, you put it in gear again......................Any was I'm sold on this valve body
But since your going with a Goerend T/Q ....might not be such a bad idea to go with there performance valve body.............I just don't now any thing about them.
Flash.
