hx40 60 62 14
Re: hx40 60 62 14
Postby kyled19 » Thu Oct 01, 2015 9:10 pm
another question i had is what are the guys running these turbos doing with the solenoid? what are you guys doing to keep the stock wastage functioning and still run 30 to 40psi?
93 d350 extened cab dually dennyt stage 2, 3200 rpm gov spring, intake, 4 inch exhaust, he351cw, fass lift pump, and an a518. 4th gen seats
kyled19
Re: hx40 60 62 14
Postby BILTIT » Fri Oct 02, 2015 6:49 am
I dont use the stock wastegate, it is tacked shut. Solenoid is removed and hole plugged. (NOTE: a funcioning wastegate is the best option).
You have to remember that the small housing is open (not divided like others) and also a 4" (VS 3" of the stock 1st gen stuff), both of these help it run cool.
Derek B.
BILTIT
Re: hx40 60 62 14
Postby RCCUMMINS89 » Fri Oct 02, 2015 4:26 pm
If you leave everything on the turbo stock.........you can leave the solenoid alone and the gate will open at 20 psi. Put 12 volts to it, and it'll open at 40psi.
Re: hx40 60 62 14
Postby Douglas » Tue Oct 06, 2015 8:43 am
RCCUMMINS89 wrote:If you leave everything on the turbo stock.........you can leave the solenoid alone and the gate will open at 20 psi. Put 12 volts to it, and it'll open at 40psi.
That sounds like the opportunity for a proper Mad Max switch on the gear shift. Stand on it, and when 20 psi is not enough, flip the switch...:)
How does that solenoid like getting hit with voltage nearly continiously? I assume that the thing could be set to open at 30 psi with 6V to the coil?
cheers,
Douglas
1991 D250, 727 and 16cm H1C.
Douglas
Re: hx40 60 62 14
Postby BILTIT » Tue Oct 06, 2015 9:18 am
no, 6v does not equal 30psi unfortunately.
Its a solenoid=20psi/40psi control only (on/off).
Derek B.
BILTIT
Re: hx40 60 62 14
Postby PToombs » Tue Oct 06, 2015 4:42 pm
Douglas wrote: I assume that the thing could be set to open at 30 psi with 6V to the coil?
Holy crap, I never heard an engineer assume before! You know what happens when you do that, right?
Re: hx40 60 62 14
Postby kyled19 » Tue Oct 06, 2015 11:23 pm
how do you put the 12 volts to it and can it just handle a continuos 12 volts? cause i would like to run 40 psi
kyled19
Re: hx40 60 62 14
Postby RCCUMMINS89 » Tue Oct 06, 2015 11:50 pm
Toggle switch. Negative to one wire on the solenoid, positive to the other.
Re: hx40 60 62 14
Postby kyled19 » Wed Oct 07, 2015 2:04 pm
awesome so if i run it threw key power then that could acted as my "switch" correct then i would just be able to make 40 psi all the time. this wouldn't hurt the solenoid correct? if i can do this I'm definitely going with this turbo!
kyled19
Re: hx40 60 62 14
Postby RCCUMMINS89 » Thu Oct 08, 2015 1:15 am
I wouldn't think so. I ran my solenoid that way for a long time.
Re: hx40 60 62 14
Postby kyled19 » Thu Oct 08, 2015 7:57 am
awesome thank you for all your info! i really appreciate it!
kyled19
Re: hx40 60 62 14
Postby DMan1198 » Sun Oct 11, 2015 6:28 am
Way to live up to your sig Pete.
