14mm unreliability
Re: 14mm unreliability
Postby PToombs » Sun Dec 06, 2015 3:42 pm
HAHAHAHA, I was going to add in "Thank Goodness for the Hungry Diesel" but didn't, and you busted me in under 5 minutes. :lol:
Postby spencerdiesel » Sun Dec 06, 2015 7:12 pm
:pale: I'm gonna start havin to play the lotto more often now. That's it I'm determined
H1C/18
Muffler delete
spencerdiesel
Postby JQmile » Sun Dec 06, 2015 8:51 pm
:D Determined to do what??
You've been all over :lol:
JQmile
Postby RCCUMMINS89 » Sun Dec 06, 2015 9:43 pm
Not to scare anyone........but in order to "do things right". Expect to be into performance mods about $6,000.00 (with a manual) at minimum before the truck is ready to attempt a 14mm h/r.
Postby spencerdiesel » Mon Dec 07, 2015 7:30 am
Determined to own a 10k sq ft IP machining shop once I win the lotto, confirmed after RC's post :santa:
H1C/18
Muffler delete
spencerdiesel
Postby spencerdiesel » Sun Feb 14, 2016 8:11 pm
Is KTA's yellow truck in mothballs?
H1C/18
Muffler delete
spencerdiesel
Postby t_ruffcorn » Mon Feb 15, 2016 7:00 am
The following is direct from rockentech
Here are some accommodations for the use of 14mm head: To run an electric pump with a high pressure seal and seal retainer, to keep the fuel flowing through there so that you can maintain it cool. You may also need a big set of injectors, such as with 6 x .016" (0.4mm) nozzles, and a big turbo charger or turbo chargers as well as fuel line upgrades (esp. using .120" / 3mm I.D. x .315" / 8mm OD lines). It is also recommended to use a high rpm spring (we currently not provide) and solid rollers.
You would have enough flow in your pump if you replace your stock rotor head with a 14mm version. However with the combination of 4mm camplate (also available) and a 14mm head you’d be working on extra accommodations to mitigate the extreme fuel flow due to the higher lift. Works could include handling higher rpm and timing and other issues including checking plunger and any other mechanical clearance, etc.
1993 w250 280k, 5 speed, 6x13 @80lpm, BD pin, 63/68/.80, 4200 gov, fluidampr, studs, springs, pushrods, 182/214 hamilton, W/M, steedspeed, PS I/C
t_ruffcorn
Postby DMan1198 » Mon Feb 15, 2016 7:45 am
I think kta turned the pump down, and is just driving the yellow truck
Postby spencerdiesel » Mon Feb 15, 2016 7:52 am
How many miles he put on it making big numbers?
H1C/18
Muffler delete
spencerdiesel
