need help, twins and ve
Postby PToombs » Sun Jan 13, 2008 5:44 pm
You can get remote oil filter housings that bolt on in place of the filter head plate. I've seen them on excavators, never thought to get the CPL number. :cry:
Postby rbrettctd » Sun Jan 13, 2008 6:10 pm
Amsoil makes them as well.
Randy
rbrettctd
Postby cummins king » Sun Jan 13, 2008 6:21 pm
i thought i was better to run it abouve the frame beween the block and frame easyer for the piping, and plus the cops will ripe your plates off the truck if the exhaust doesnt run behind the cab
93 4X4 auto
cummins king
Postby cummins king » Sun Jan 13, 2008 6:25 pm
rd you got a website
93 4X4 auto
cummins king
Postby KTA » Sun Jan 13, 2008 7:37 pm
My Hx60 fits with the oil filter still on it so your HT60 should too. Look at my pics on diesel-central they might help you see how I did it.
Postby cummins king » Sun Jan 13, 2008 9:27 pm
thanks kta
what do you guys use for a blow off valve, there tons of them on ebay but there for cars
93 4X4 auto
cummins king
Postby cummins king » Sun Jan 13, 2008 9:45 pm
you know why it dont fit so nicley its reverse rotation
you know i begging to think its not big enough
kta you got your truck to do a buck and a half thats crazzy :shaking2:
the pictures arnt working
http://www.diesel-central.com/photog...Cat4%5FI D%3D
that is what your refering to right :?:
93 4X4 auto
cummins king
Postby CumminsPride » Mon Jan 14, 2008 6:02 am
Album number 107 and they worked fine for me.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby KTA » Mon Jan 14, 2008 6:15 am
The reverse rotation should make the exhaust side easier, but the comp side will be a bit more tricky.
Postby cummins king » Mon Jan 14, 2008 8:23 am
sorry kta i kind of disagree
to get the turbo under the top turbo requires it to be close to the block, i can move it out but then the frame is in the way for the exhaust
93 4X4 auto
cummins king
Postby Cschafer » Tue Jan 15, 2008 11:40 am
Blow off valves are for cars with throttle plates.
91 w250 wrecker
Cschafer
Postby cummins king » Tue Jan 15, 2008 5:05 pm
you know what i mean waste gate lol :lol:
93 4X4 auto
cummins king
Postby cummins king » Tue Jan 15, 2008 5:11 pm
today i almost finished the hot pipe a little more welding and gringing needed, im going to have to punch the oil pan, but other then that and the remote filter housing its almost done, i still ahvent found the filter housing yet any body know the part number on the exovators
thanks
93 4X4 auto
cummins king
Postby Underpsi » Tue Jan 15, 2008 5:44 pm
Call cummins, you said the guy was pretty good last time you called. If you remember his name ask for him and maybe he can find the remote housing for you. P.S. Did you ever pick up your throttle ends?
1989 D250 5spd w/SB3250DD, .020 over head gasket, O-rings, Extensive port/polish, ARP head studs, 62/71/14, 6x.018 sticks. First Dyno stock turbo and pods: 343/879
2nd with 62 & big sticks: 393/813
Underpsi
Postby cummins king » Tue Jan 15, 2008 6:48 pm
ya i got everything yesterday 12 bucks for each side not bad, oh did i tell u it was my b day today :bday:
oh and i also got my other ic pump today
93 4X4 auto
cummins king
