Another IP Thread
Postby cummins king » Thu Mar 13, 2008 7:35 pm
to make 400hp you can do it with a stock 12mm head, so 1/2inch lines pickup to the piston pump to the ic pump you could also put a good eletric pump in, just read the threads its all explaned there,
boost regulated means that the fuel pressure goes up as the boost goes up, im sure you know that though
what do you mean buy ip rings
93 4X4 auto
cummins king
Postby VEfreak » Thu Mar 13, 2008 9:48 pm
I meant the IP inlet and the snap ring. Complete fuel system upgrades are new to me. I'll have to look all this stuff up and learn much more about it.
VEfreak
Postby DTanklage » Thu Mar 13, 2008 11:31 pm
do a search
that stuff should be all thru here
dont know that you will need to go very crazy for 400 hp tho...
DTanklage
Postby CumminsPride » Fri Mar 14, 2008 4:34 am
Look in CumminsKing's sig at his photo bucket.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
