Anybody here know anything about hydraulic systems?
Postby PToombs » Sun Apr 13, 2008 4:01 pm
Begle, 72-78 dodge pickups, rpms weren't very fast. I know I don't have any pics of mountings. Picture 2 halves that go around the pump with a pinch bolt, 1 has a flat plate welded perpendicular to it with mounting holes. This bracket goes around the front, the rear has a narrow 1/2 inch band with a piece of threaded rod to a bracket on the engine as support.
Postby flashgordon » Sun Apr 13, 2008 8:57 pm
Begle1 wrote:The one on the right is the stock air compressor that I took off my truck so that it would go faster.
The one on the left is the hydraulic pump that I'm going to put on my truck so that it will go faster.
They got the same size shaft, seems to me like I gotta find a new A/C clutch to mount on the hydraulic pump.
Need to find a way to mount the pump itself too.
Got Ya!!!
I though you were trying to make 1000 psi pump out off an ac compressor
flashgordon
