which injector?
Postby sdstriper » Thu Apr 24, 2008 3:09 pm
What do you use the truck for? Do you ever tow? Or are you rodding around in it for funsies? It matters alot. Do you have an EGT gauge?
You can get a heck of alot of power gains with very little investment before you dump a bunch of money into injectors. If you don't have an EGT gauge, get one before anything else. Then, I personally would turn that pump up if you haven't, then buy an Old Smoky Fuel Pin or grind one, and get a 3200rpm governor spring. After that I would get a better turbo. Add the intercooler. Then If you think you want/need more power, you can look into injectors.
I agree with Daniel. You already have the edge over the intercooled trucks with the injectors that are in the truck.
sdstriper
Postby 89silverbullet » Thu Apr 24, 2008 7:13 pm
i tow a gooseneck with a backhoe and every now and then i will go and smoke a bicycle rider... or 2... or 5 :rock: . but i am doing the upgrades as steadily as the cash flow go's. by the way, what is the best pyro gauge i can buy and where can i get it. all the morons at every auto parts store in san antonio looks at me like i asked them for spark plugs for my cummins :shock: .
1989 d250 muffler delete diaphram turned, fuel screw turned, the lowes special intake
89silverbullet
Postby cummins king » Thu Apr 24, 2008 7:55 pm
mine is a chepy sunpro, seems to be working fine, for 100+ bucks i got a pyro and boost and a tranny temp not bad, if you towing heavy your not going to want huge injecotrs maby a set of 370's or somthing like that, unless you want to go to twins
93 4X4 auto
cummins king
Postby 89silverbullet » Fri Apr 25, 2008 12:22 am
where did you get three gauges for $100 bucks. i'd like to know!!!
89silverbullet
Postby cummins king » Fri Apr 25, 2008 9:06 pm
ebay,
93 4X4 auto
cummins king
Postby PToombs » Sat Apr 26, 2008 4:31 pm
Joel, was there supposed to be a link there? :?
Postby cummins king » Sat Apr 26, 2008 6:42 pm
ha no, i got to do everything.. :lol: i will see if i can find it again
Joel
Sorry Guys, i checked ebay and found nothing
93 4X4 auto
cummins king
