lp ??
Postby dragrdan » Thu Oct 02, 2008 7:11 pm
so is there a # for the low pressure spring( or a rebuild kit #) or do you have to buy both pumps to get it?
dragrdan
Postby DTanklage » Wed Nov 12, 2008 12:21 pm
somewheres on here or the pay forum there is a list of the pn's and diff pressures
let me know where it is if you find it please
don
DTanklage
Postby MMiller » Thu Jan 22, 2009 5:21 pm
PToombs wrote:Cummins part numbers-
# 3936320 lift pump (qty 1)
# 3914753 Fuel Line (qty 1)
# 3931348 Gasket (qty 2)
# 3914284 Spacer (qty1)
# 3918191 Seals (qty 2)
Is there anything else before I go to bed? :roll:
:jumpsmile:
I just called my local cummins shop with these part numbers. They told me the numbers had changed on some of the parts.
4988751 is the new lift pump number- $174.39 not available until Feb 16
3939258 is the new gasket number, need two-
3963983 is the new seal number, need two.
He said nobody had the old number, so I guess I'm SOL for now, unless someone else here can find one. I guess it will be next month until I can upgrade lift pumps.
Michael
MMiller
Postby lazyjoe » Thu Jan 22, 2009 6:53 pm
Just picked my pump up today at my local case i/h dealer.
1 fuel line #J914753- $21.95
1 spacer #J914284- $11.15
2 gaskets #J939258- $3.22 each
2 seals # 87415913- $2.37 each
1pump #J936320- $157.37
plus $12.00 freight.
total- 213.29
Joe
93, W350, auto, DTT convertor, 4.10's, GDS 60mm with 14cm, piston l/p, 2nd gen air horn. 366 spring. boost, and pyro.
91, W250, 360 gas, auto, 4.10
95, 2500, 4/4, 5" turbo back. So far.
lazyjoe
Postby DTanklage » Thu Jan 22, 2009 7:11 pm
good job
i got one of those pumps left...
the high press 2nd gen
the one with the big fittings
new in box
DTanklage
Postby MMiller » Thu Jan 22, 2009 7:43 pm
Joe, is your's indeed the hi pressure one? Or did it change part numbers too? I getting confused as the part numbers are not staying the same.
I don't want a high pressure one, just want the higher volume piston pump for the VE. Ain't going crazy power, just good solid reliable power.
Michael
MMiller
Postby lazyjoe » Thu Jan 22, 2009 8:05 pm
Mine is the low pressure pump. (So I was told.)
Joe
lazyjoe
Postby DTanklage » Thu Jan 22, 2009 10:11 pm
if ya wanna know for sure before using it (owning it) measure the installed ht for the spring and throw it in a spring tester at that height
that way if it is not what you wanted you can still exchange it
DTanklage
Postby PToombs » Fri Jan 23, 2009 6:12 pm
If Joe got the original pump he's lucky. When I got one for 1991cummins on here last month, there were only 3 in stock at Case dealers, country wide. The part number was being superceded again, and the new pump is going to cost about $300. It is due out around February I think.
I just looked at the receipt, the last pump part # is 87648730, this is the updated, same pump, part number.
I'll try to remember to post the newest pump part number, when it comes out.
Postby DTanklage » Sat Jan 24, 2009 9:42 am
was that with the big or small piston?
DTanklage
Postby PToombs » Sat Jan 24, 2009 6:30 pm
Small one.
Postby DTanklage » Sat Jan 24, 2009 8:01 pm
why run the small one???
i dont get it
my truck started suckin the big one dry around 375 hp
of course a lot of it has to do with plumbing
and where the fuel tank is mounted
tank
DTanklage
Postby SChandler » Sat Jan 24, 2009 11:17 pm
Why run the small one? Because the small one does a pretty good job of supporting 300hp, doesn't require new fuel lines from the tank to the injection pump, and the R&D has already been done by many different people. Your racing background gives you a different mindset from most members on here. Most of us are stingy SOB's or are broke (or both) and just need a little bit more than what the factory pump can handle. Thus, the ever popular low pressure piston LP swap.
SChandler
Postby peobryant » Sun Jan 25, 2009 1:03 am
SChandler wrote:Why run the small one? Because the small one does a pretty good job of supporting 300hp, doesn't require new fuel lines from the tank to the injection pump, and the R&D has already been done by many different people. Your racing background gives you a different mindset from most members on here. Most of us are stingy SOB's or are broke (or both) and just need a little bit more than what the factory pump can handle. Thus, the ever popular low pressure piston LP swap.
That pretty much sums it up. :lol:
Postby DTanklage » Sun Jan 25, 2009 1:07 am
this style pump is prolly good for half a million miles at the low rpm these motors turn
if you are broke go to the junk yard and buy a used one for 15 bucks
then you can use the other 150 bucks redoing the lines and fittings. trust me. your 15+ yr old truck needs new fuel lines. all the way from the tank to the ve
DTanklage
