Begle's Water Injection
Postby cummins king » Sat May 31, 2008 8:22 pm
looks good, that hydrolic pump will work well, ive seen a few PPumped trucks ith thems, good luck
93 4X4 auto
cummins king
Postby mhuppertz » Sat May 31, 2008 9:07 pm
This would be perfect, just too pricey!
http://cgi.ebay.com/ebaymotors/0-100-PS ... .m20.l1116
mhuppertz
Postby Fnschlaud4620 » Thu Jun 05, 2008 8:35 am
Any updates, how much more power does it make?
I ordered my coolmist smart controller last night. Thanks
Fnschlaud4620
Postby Begle1 » Thu Jun 05, 2008 12:00 pm
On the way out to California it gave me 10-15 MPH higher top speed without going over 1250 degrees at the pyrometer.
I was a little bit disappointed, but when I got done with that 330 mile test drive I realized that I forgot to put the fuses in all but my smallest solenoid. :cry:
Once I got to California and my old home town the fuzz started pulling me over three times a day, so I was a bit too scared to do much in the way of testing.
On the way back I had some kind of wiring issue due to electrical connections laying in the bottom of a tool box full of water, so the pump didn't work real well.
And now Diesel is $5.00 a gallon, I am unemployed, and I owe the machine shop $1000 I don't have... :x
I had all three solenoids working for a couple days. I had everything opening by 15 PSI. It doesn't make that fast of a drop, but it seems to keep dropping temperatures for a long time. I can still go over 1250 easy, but I don't need to throttle back nearly as hard to keep it at 1250. Whereas before I could accelerate at half throttle at a sustained temperature, now I can accelerate at about 3/4's throttle.
But, I need to figure out a way to make sure I'm flowing any water at all. I don't have too much confidence in my little pump.
Postby Begle1 » Sun Jun 08, 2008 2:28 pm
Haven't pressure tested it yet, but checked the nozzles and flow tested them.
Little nozzle:
Little and middle nozzle:
Little and middle and big nozzle:
I didn't notice any major drop off in pressure with all three going. The only drops you can see with all three going are a few that collect and stream off the diffuser wire on the big one.
I ran them all into a bucket for 60 seconds and only got 9 cups, or 9/16's a gallon a minute (34 gallons per hour). Not quite the rated 40 GPH at 100 PSI, but respectable. I think another pump in series should get over 40 GPH...
The diffusers were all solid still. I don't think they're going anywhere (knock on wood).
