by fergavs » Fri Oct 24, 2008 6:56 pm
I ran a piston lift pump for a couple years. that thing worked well for 300-350rwhp. I am gonna install the piston pump on the 91 I just bought. I didn't have a fuel pressure gauge back when I was using the piston lift pump but it never seemed to go dry. When I did my last round of mods I upgraded to the airdog150. I just blasted a hole in the bottom of the tank and use a fitting with a viton seal. I don't use the stock pickup at all. I also have all 1/2" lines and a 3/8's fitting into the IP.
