Beginners starting line.
Postby slingshot » Tue Nov 04, 2008 8:37 pm
That does help. I was concerned because the thermocouples that I have, come from the Peterbilt dealer, and all of them (including my spares) are already put together and from the bottom of the fitting to the end of the probe was 2 1/2" so I didnt think that the manifold was deep enough to accept it. However, I carefully cut the compression sleeve off so now I can slide the probe up to where it needs to be. Thanks for everyones help.
1993 W250 5speed.
slingshot
Postby cedardiesel » Thu Nov 06, 2008 5:37 am
Hey that 94 model turbo is most likely a WH1C with the 12cm2 housing it is a slight improvement over your current H1C cause it has a slightly larger compressor wheel and the smaller exhaust housing
90 W250 4x4 5spd pump Ve cranked wide open, BHAF, HX35 with all 2.5" intake piping, and 4" straight piped
92 W250 4x4 5spd P-pumped B1B over B2 are on and now slippy clutch
cedardiesel
Postby MMiller » Sun Nov 09, 2008 7:18 pm
I put a Super 40 on my 93 this year, and would do it again in a heartbeat. I too tow heavy, grossing upwards of 30,000#. I've got an old set of Bosch 185,s(bought when they were cheep), and the pump tweaked. About 2.5 turns of the fuel screw and little more timing and the star wheel down at the bottom. I'm not currently running the ground pin as before it was too hot with the stock charger. With 3.55's and current tune, the pyro does not get over 1300*. I have no water/meth at this time. I do have a second gen aftercooler that may find its way on the truck this winter. I'm also planning on some of Tim's Cooler tubs.
My truck will run down the road pulling a load with a new Ford or Dodge diesel. I did not read it anywere, are you auto or manual?
Michael
MMiller
Postby slingshot » Wed Nov 12, 2008 5:15 pm
The ole getrag! I hauled a 29000# forklift this past weekend, neither the truck nor the trailer liked it too much.lol
1993 W250 5speed.
slingshot
Postby cedardiesel » Wed Nov 12, 2008 7:40 pm
I would think not cause I hauled 20000lbs and my frame twisted through 1,2,and 3 gears and I would hit 25 lbs boost in first gear even with 4.10s and my EGTs were 950 post turbo temps and that is with what little bit of mods I have
cedardiesel
Postby slingshot » Fri Nov 14, 2008 6:44 pm
Yea, I had to put it in low range to back up or to take off on a steep incline.
1993 W250 5speed.
slingshot
Postby SNOOT » Fri Nov 14, 2008 10:48 pm
1993 W350
SNOOT
Postby cedardiesel » Sun Nov 16, 2008 11:18 am
Yea I had to do the same for backing up but not going up the inclines from a stop and hey SNOOT it must be nice to have money LOL :( I'll eventually get there I'm only 17
cedardiesel
