Agreed. As a guy who drives a stick truck in heavy traffic every day, drivability is more important to me than max HP.
3rd gear launch will take a Honda.
Not overdriving it now with the POD's, (then again I haven't put the screws to it) but once I install my Scheid EDM's, it's gonna gain upwards of 10psi of boost. That might be running a little high for a hx35.wannadiesel wrote:With that little boost I don't think you're going to see much difference in HP. Maybe 10 HP. It's not like you are seriously overdriving it with the 16 cm. It certainly will drive better with the 16 cm.
seeker1056 wrote:ok so what is a stock 1996 hx35 housing in size, and what should I expect for boost with the 12, 16, 18, 21 housings should I switch?
Thanx
