BC847 wrote:...backing out the fuel screw a good two or three turns only made less smoke (and slower track times)..
But still no effect on spool - still slow to spool? If so, the factors don't seem to jive together. Once the fuel level return to a point where it's burning good spool should return to normal.... unless there is another reason for the less than otimal combustion.
Is there some point at which the injector size overcomes the pump's ability to flow enough fuel at a high enough pressure threshold for proper atomization and a good burn, regardless of timing? Assuming a "not" new pump or at least a "very healthy" VE?
