I looked at a set of 96 215hp 5x.010" and they are 145deg.
I still have yet to find my 89 injectors and check them, but I will!
KTA wrote:I looked at my IC 6x 0.009" injectors and they are 145deg.
Richie O wrote:Ok, so I have been reading some injector stuff.
The non cooled trucks had a 155* spray angle.
all the 12 valve intercooled trucks ( including p pumpers ) have 145*. as said by KTA![]()
There is no such thing as a stock 435 horse injector in any mechanical 12 valve ( including industrial, marine ext. )
There is no mechanicaly injected ( ve, cav, p pumped ) stock 6b over 370 horses. ( all the big horse marine over 370 are electronic common rail engines. ( Quantam series )
A stock "marine" 370 tip is the wrong spray angle for any 145 degree sprayed truck. The industrial's use the 155* angle with the bigger piston bowl.
Man I thought I had a handle on the injector basics. Boy was I wrong.
Remps wrote:Were both sets of injectors in your brother's truck the same size? Pop pressure?Or was spray angle the only variable? Also it would be cool if the injector chart Sticky was updated with spray angles,though I'm sure most of them are 145 degrees.
Richie O wrote:Well Parker I may make a rough draft and let KTA read it. I don't want anyone to think I know what Im talking about cause I don't.
peobryant wrote:and the people here will actually listen, rather than argue.
chico_mustangs wrote:I'm so confused... Ok so I called up pensicola diesel and they told me that all of the injectors from 88-93 are the same and the only ones that are different are the auto vs manual which I know is untrue. I asked him a couple other questions, he had an attitude and pretty much blew me off. He also didn't know what the pop pressure or angle was.
I spoke to an older gentleman at Diesel Care & Performance, he told me that the 91.5-98 Injectors are all interchangeable and the ones they sell fit that year range. He also told me the pop pressure was 250 bar. He said that they have 60hp for $289 and 100hp for $329.
Can anyone make any sense of this? All I want to know is which injectors to order, I don't need anything crazy and don't plan on ever making crazy power with my truck. All I want is to be able to easily pull 8k lbs up a hill without going 35mph. I have a fuel pin, full 3-3.5in exhaust, turned up wheel, and an intake.
Users browsing this forum: No registered users and 62 guests
