Latest spring and results :
I ran my 13 mi test route which includes city and hiway. Actually 2 different hiways so I can set cruise to 68mph and then hit the 270* exit ramp which slows me to ~ 35mph, then I hit the resume and let the cruise accelerate back to 68mph. This way I get a feel for how the mods affect city driving and I know the hiway acceleration is pretty much the same since the CC is doing it.
New Spring
http://www.cumminsforum.com/gallery/sho ... puser/9741
This spring reaches a maximun of 35lbs pressure for full compression. This spring is actually 0.23 shorter than stock. Next spring will be a little longer and I'm shooting for a 50lb spring.
Stock spring travel - max boost reached ~ 15psi
You can see where the track is past the slope and nearly at maximun extension. Some smoke but not a blackout that clears by 50 mph.
New spring travel - max boost same
You'll notice the track is barely at the end of the slope. Very little smoke initially that disappears quickly.
For those who wonder about the effectiveness of a valet switch, here's a photo with the valet active - ie blocking boost from the AFC
Look VERY close at the bottom of the pin, you'll see a shiny spot where the guide pin was touching the fuel pin. I had to rotate the pin a little so the spot would show up better in the pic. The pin didn't move down at all. Surprisingly I was still able to hit 15 psi boost when I got into the throttle. Virtually no smoke other than the haze I have all the time.
Haven't hit full throttle yet to see if I've lost anything on WOT. I have noticed EGT's down by ~ 100* so I'm definitley getting less fuel at the same boost and road speeds.
All these tests included a heavy blip on the throttle in town to see if I could smoke-on-demand and the answer is definitely, but different amounts from a cloud to a large puff when the valet is on.
'93 D250 CC 47RH w/goodies HX-40 60/65/17 w/hx50 flange 55 psi CoolerTubZ 6x16's M2 pin, 4"dp->5" pipe->5" Stack, PS IC
