Injector advice?
Postby PToombs » Sun May 20, 2007 7:05 am
If the lines are leaking try to loosen then tighten them again. DO NOT torque them tighter and tighter! Or you can loosen them and try to make sure they are straight when you tighten them. I usually do the loosen/ tighten with it running, if there is a little crud in there it will blow out.
Good Luck, glad I could help on the injectors! :)
Do you plan on going to SOP this year? If so, I'll see ya there! :D
