2001 7.3 electric LP
Re: 2001 7.3 electric LP
Postby Remps » Thu Dec 30, 2010 11:33 am
Well that pump came back off after a couple days. :roll: I put the $20 pump back on that makes .25 psi at an idle. Better than tryin to drive and turn the pump on/off. I now have a 1" inlet/outlet pressure relief valve preset @ 15 psi, adjustable from 3-25 psi. I'm wondering if I can plumb it in between the LP and the fuel filter, and tee the return back into the inlet of the LP? Or do I have to put in a separate return line? I really don't want to mess with the IP's return line.
Users browsing this forum: No registered users and 65 guests
