cheap monster turned money pit ;)
Re: cheap monster turned money pit ;)
Postby motorwood » Sun May 01, 2011 11:06 am
Just added a super 40
'03 2500: utility body stock; '92 350 flatbed: maxed fuel, 354 spring, 6x.016's, 14mm H/R, 2.8plate, studs, springs, A1000 5/8 line, Super40 = 454hp 1080tq all fuel. Have added S3 66/74/.91, O-rings, home port job, Steedspeed t-4 manifold. Hp=437/857 :( 13mm P, 5x.025, he551+ht80 843hp 1thousand something trq. Broken 5th gear.
motorwood
Postby dazedandconfused » Sun May 01, 2011 11:14 am
Does it feel any stronger with the super 40?
Postby motorwood » Sun May 01, 2011 6:21 pm
the roads were wet, my tach and pyro were out of the dash so couldnt tell and I'm having some timing issues. A little less boost (wastegate) than the w1c/e. It was pushing 50psi way too much.
motorwood
Postby motorwood » Tue May 03, 2011 6:51 am
checked timing, it was 16 and not advancing with rpm. My pump is a non Dodge application and I dont know what the advance curve is, gonna lock out the advance set it about 30 degrees and dyno it. I have a miss that I'm trying to find. I fear it may be a burt/bent valve or a headgasket. Gonna do a compression test today.
motorwood
Postby motorwood » Thu May 05, 2011 4:26 am
replaced injectors, did a compression check (all 6 holes right about 400psi) re-checked the valves, taking off the 14mm pump and putting back on a stocker. I'm disappointed that Im not gonna have the 14 for 7May's dyno day but I've got to find that miss!
motorwood
Postby Subliminal » Thu May 05, 2011 10:37 am
That's the problem with changing a bunch of stuff at once...hard to track down the gremlins.
Good luck!
Subliminal
Postby motorwood » Fri May 06, 2011 7:53 am
stock pump back on, seems to run smoother
motorwood
Postby motorwood » Sun May 08, 2011 6:21 am
383/869
motorwood
Postby motorwood » Fri May 20, 2011 8:49 am
Tach working, cable shut-off, and the short in the instrument lights fixed. Pulling saturday night at Mont Alto, PA !!
motorwood
Postby motorwood » Wed May 25, 2011 6:41 am
106.75' in the stock class,not good but I think I beat 3 other trucks. 93.0 in the 2.8, probably last. A good lesson on pulling on a wet sticky track. The sled pulled very heavy and slow. 11 june is the next pull. Next project is new tires and putting my 14mm pump back together.
motorwood
Postby oldestof11 » Wed May 25, 2011 1:14 pm
Dude, thats all? :?
Musta been REALLY sticky! When I pulled on a looser track, I pull 198, and 193 on a 250ft track. TO put it in perspective, I was 2nd to last on both. When the sleds air bags filled, game over.
I had a maxed pump, original 200k+ clutch, stock injectors, stock turbo, stock sized tires (fronts were bald, thank you Walmart), 3200 rpm spring. Clutch held!
Postby motorwood » Wed Jun 01, 2011 6:30 am
Yeah, got to love those bald stock sized tires! Next pull is 11June, hoping for a looser track and some new tires. Would love to see how the 14mm would do, but probably wont have it (the pump)back together by then. Just have to pull the 12mm again.
motorwood
Postby motorwood » Sun Jun 05, 2011 6:47 pm
decided to head to a rare Sunday pull after church. 4th out of 5 and drove the truck home. Competing against (and loosing to) chipped up commonrails is getting old. I need to get my 14mm pump back together, not that I'll win but more HP can't hurt.
motorwood
Postby motorwood » Sat Jun 11, 2011 4:45 am
pulling tonight, got the 14mm back on but have to take it off today to fix a fuel leak. It feels pretty good but a little hard to tell with a 1940lb block o concrete and another 800-1000lbs of watertank on the bed.
motorwood
Postby motorwood » Tue Jun 14, 2011 9:12 am
7th out of 15 best finish yet. dyonoing today to see how the numbers look with the 14mm back on with correct timing/governor control.
motorwood
