Non intercooled injectors What size should I make?
4x.014
1
3%
4x.015
2
5%
4x.016
14
36%
4x.018
13
33%
8x.010
3
8%
8x.012
6
15%
Total votes : 39
Re: Non intercooled injectors What size should I make?
Postby spencermumma » Wed Jul 27, 2011 9:15 pm
Any 6x16 non ic?
1990 Dodge W250 5 inch stacks no muffler, Star wheel bottomed out, Smoke screw turned all the way, Fuel screw maxed, Denny T Fuel Pin, 2inch lift with 33x12.50 and alot more to come shooting for 450 horsepower any suggestions?
spencermumma
Postby shiftycapone » Thu Jul 28, 2011 11:06 pm
So no more 4 hole stuff I take it?
Also were the nozzles just being edm'ed to the specified size? Or were these nozzles from a different application? I would like to try a larger 4 hole.
1990 D250
shiftycapone
Postby tampabayBill » Fri Jul 29, 2011 7:06 am
How much for a set of 5x16 145 nozzles
Twins coming soon!
tampabayBill
Users browsing this forum: No registered users and 106 guests
