Injector Porn
Re: Injector Porn
Postby delinquent » Thu Nov 04, 2010 9:56 am
All the turning down thats being mentioned in this thread is from turning a 9mm injector tip down to 7mm so it will work in the 91.5 and up head.
delinquent
Re: Injector Porn
Postby Ace » Thu Nov 04, 2010 12:33 pm
delinquent wrote:All the turning down thats being mentioned in this thread is from turning a 9mm injector tip down to 7mm so it will work in the 91.5 and up head.
It will "fit." How well it would "work" is probably debateable. Spray angle is still for a non-IC piston. I considered doing this with a set of non-IC injectors I have, until I found out about the spray angle.
Ace
Re: Injector Porn
Postby oldestof11 » Thu Nov 04, 2010 1:21 pm
No different than POD's though.
Yes, it allows a NON-IC 9mm tip to go into a 7mm head. Sled pullers do this to a Cat injector because its about 1/3 the price...
I plan on timing the thing WAY ahead...
