injectors
Postby Ace » Sat Jul 28, 2007 12:22 am
Begle1 wrote:...If the black smoke gives us a bad reputation, beating the occasional muscle car counteracts that a little bit, right?
I guess that depends on your definition of "muscle car." If it's not doing 13s or better with a normally aspirated American V8, then it ain't a muscle car in my book. Not many Dodge Cummins pickups can make that claim.
Ace
Postby CAJUN 93 » Sat Jul 28, 2007 6:36 am
yep, any true musclecar (intermidiate body, big block engine) from the mid 60's to early 70's is a 13 sec car with todays tires. don't let those mid 14 sec time slips from the late 60's fool you. try hooking your truck up on g70 bias plys :lol: :lol: .
now, back to the subject at hand. i'm modding the wife's ride (finally!!) and have some pod's i bought earlier. will the edm's make enough of a power difference to make it worth selling the pod's and installing the edm's? i'm shooting for 350 hp on #2 and more with h2o/meth. and if so, anyone wanna buy some new in the box piers pod's?
daryl
CAJUN 93
Postby TWorline » Sat Jul 28, 2007 6:50 am
CAJUN 93 wrote:yep, any true musclecar (intermidiate body, big block engine) from the mid 60's to early 70's is a 13 sec car with todays tires. don't let those mid 14 sec time slips from the late 60's fool you. try hooking your truck up on g70 bias plys :lol: :lol: . daryl
Oh yeah, the good old days!!! :lol: That was a chalenge even with a small block! With 600 ft. lbs. of tq. it would be like being on ice.
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby PToombs » Sat Jul 28, 2007 5:31 pm
G70's? I was running 60's on my '69 Chevelle 'vertible, and toasted them all the time! Of course, with a BB 396, 4 speed, and 4.88's, what do you expect? :twisted:
The guy I got it from had it since high school, it was a consistant class winner at the local strip. Once he had 9 or 10 inch slicks on it, broke the wheel studs clean off! :oops: :wink:
Postby Begle1 » Sat Jul 28, 2007 8:51 pm
So small block Mustangs aren't muscle cars?
I'd classify them as muscle cars, I guess "Pony Cars" would be more accurate, though...
Postby rbrettctd » Sun Jul 29, 2007 2:35 pm
What are the 370s edm compared to the 435s?
Randy
rbrettctd
Postby DLittle » Sun Jul 29, 2007 2:48 pm
The 370's are a 5x12 435's are a 5x14 from New ERA Diesel
Dana
1992 W250 auto, 290 k, stock for now SOLD
1973 W100 SWB, D70,D60, 5.9 Twin Turbo SOLD
1993 W250 193k, Auto, TOTALED 10/30/2009
DLittle
Postby rbrettctd » Sun Jul 29, 2007 3:18 pm
So the 370s are a little milder?
Randy
rbrettctd
Postby MikeThomas » Mon Jul 30, 2007 8:55 pm
How are those 370's? Do you wish you had stepped up to the 435's?
1993 W250, 5SPD, ne370's, HTT STAGE IV/14wg, DennT Pin, BHAF, P-PUMP, PUMP TWEEKS, 4" EXHAUST, 366
MikeThomas
Postby DLittle » Tue Jul 31, 2007 7:22 pm
MikeThomas wrote:How are those 370's? Do you wish you had stepped up to the 435's?
I like the 370's really clean running on my setup but knowing what I know now I would have bought the 435's. I took the 370's apart and sent the tips to extrude hone to work there magic. I had them do a 45% increase on them. They put out a lot more fuel now. I'm going to dyno in August and see if I gained anything.
Dana
DLittle
Postby Falcon » Wed Aug 01, 2007 8:11 am
Did you like the 370's ? I'm wanting them for towing, With the stock hx-35 and a 16cm non wg I feel they would match up quit well. What do you think? That should get me to 300 with more pump and timing adjustments
Greg
Graham, Washington
"FIRST REAL TRUCK ENGINE...
LAST REAL TRUCK!!!
93 ex cab 4x4, Hybred 35/40,4" exaust all the way,pump turned alittle,DDP Stage III's, 366 spring,DDP fuel pin,AFE first gen air intake,pyro and boost gauges
Falcon
Postby Begle1 » Wed Aug 01, 2007 8:44 am
I thought that 370's were good for a bit less than POD's? In the 370-400 HP area?
Postby Falcon » Wed Aug 01, 2007 1:29 pm
Begle1 wrote:I thought that 370's were good for a bit less than POD's? In the 370-400 HP area?
From what I was told at newera almost double POD's 52 rwhp as the EDM's 370's are around (if I heard correct) I think were in the 85 rwhp range with better spray pattern
Greg
Greg
Graham, Washington
LAST REAL TRUCK!!!
Falcon
Postby DLittle » Wed Aug 01, 2007 5:32 pm
I liked the 370's. I dyno'd 301hp/538tq with them. Egt's were never a problem with them. I think I barely hit 1300 on the dyno. That was with a stage3 and 18.5 exhaust housing. They were verrrryyy clean running little to no smoke anytime.
Dana
DLittle
Injectors
Postby nvbullhauler75 » Mon Sep 17, 2007 10:01 am
This is my first post on this website woooooooohhhhhhhoooooooooooooo first gen only bout time anyhow thenew era injectors are better than pods less smoke and more rwhp is this correct
William M Copper Jr
nvbullhauler75
