Re: '90 W250
Postby RCCUMMINS89 » Fri Aug 16, 2013 7:19 am
The low end gain, should still out benefit the slight high end loss. I say slight - because, I feel once you get it dialed in, it won't be all that much.
Also, it will allow you to use MUCH larger injectors and still have cleanliness.
Re: '90 W250
Postby dazedandconfused » Fri Aug 16, 2013 8:06 am
Sounds like you need a bypass to open after the super is done allowing the turbo to pull more fresh air.
Re: '90 W250
Postby Tacoclaw » Fri Aug 16, 2013 9:11 am
RC, I'm thinking more like a little more timing. I've got 155* 5x14's so I may need to narrow them somehow to keep it in the bowls. I'm happy with the fuel I've got, there's no reason to go bigger. If I can ultimately end up completely cleaning them up then I'll be a happy man. 8)
Yup, I'm gonna give the little 1 1/2" one a shot that's on there but I also bought a 98mm LS1 throttle body off Ebay. It's 4" OD so it'll match my intake piping.
I figure I'll be sealing the small bypass and using its actuator to run the TB. Not now though, now in just gonna run it. And enjoy.
Re: '90 W250
Postby AHineman » Fri Aug 16, 2013 9:42 am
DodgeFreak wrote:or is your truck slower now.. :lol:
No worries there. ;)
Re: '90 W250
Postby Tacoclaw » Fri Aug 16, 2013 9:52 am
The only way my truck would be slower than Hiney's right now is if you set it on jack stands that we're welded to te floor. :P
Re: '90 W250
Postby DodgeFreak » Fri Aug 16, 2013 11:26 am
If you can weld jack stands to the floor your one heck of a welder lol.....unless your floor is a slab of steel. and do you really need to anchor the stands?? you need power to knock the truck off stands
Re: '90 W250
Postby RCCUMMINS89 » Fri Aug 16, 2013 12:20 pm
Taco - 5x14 will get you pretty much anywhere you need power wise. If you do every outgrow them, extrude hone them and they'll be more fuel than you'll be able to handle, even if you put down a new record.
being a non I/c truck..........you won't need to worry about spraying outside the bowl.
Re: '90 W250
Postby Tacoclaw » Fri Aug 16, 2013 12:48 pm
Heh, I'm not out to set any records. I'm more interested in a good sounding/driving truck than I am one that makes big numbers sitting still.
I've got a pic of one of my pistons with the head off, I'll find it tonight, and it's already shooting right to the edge of te bowls IMO. I'll post it up later for further inspection.
Re: '90 W250
Postby RCCUMMINS89 » Fri Aug 16, 2013 12:57 pm
Really? Ya, that's not good.
Re: '90 W250
Postby DodgeFreak » Fri Aug 16, 2013 1:08 pm
do they make thinner washers for the non ic injectors?
Re: '90 W250
Postby Tacoclaw » Fri Aug 16, 2013 1:24 pm
Clear back on page 18 when I did a cam swap. How in the hell are we at 122 pages now? :lol:
1/8" bump, stock tooth timing.
Re: '90 W250
Postby RCCUMMINS89 » Fri Aug 16, 2013 1:30 pm
Something f'ed up. You shouldn't be spraying outside the bowl at 1/8" bump. You sure someone didn't swap in I/c pistons when you weren't looking?
Re: '90 W250
Postby Tacoclaw » Fri Aug 16, 2013 4:11 pm
As far as I know, that engine had never been apart before I got my grubby paws on it.
What are the standard spray angles available for 5-hole nozzles? They may be a wider setup than 155* or something, who knows.
Re: '90 W250
Postby RCCUMMINS89 » Fri Aug 16, 2013 4:17 pm
You've got marine pistons (looks that way to me anyways).
155 and 145 are your options. There's others out there, but that would be as rare as finding a p pumped 1st gen straight from the factory, :lol:
I wonder if your injectors didn't seat down all the way? Thicker h/g by chance? Were all of the sprays similar between each cylinder?
Re: '90 W250
Postby Tacoclaw » Sat Aug 17, 2013 3:34 am
I've got pics of most of the cylinders back on page 18, standard HG and the thinnest washers.
I'm going to start the crossover steering this afternoon, once it's on I can then start on my front airbags, all while tuning and tweaking on the blower setup. Gonna be a busy week. Again. 8)
