Just a little more . . . . .
Postby dazedandconfused » Sat Sep 10, 2016 4:17 pm
Decide on a turbo setup?
Postby DMan1198 » Sat Sep 10, 2016 4:29 pm
Man, I don't know how you could run the same turbo setup for 8 years. I've had my compounds running 6 months, and I already want new turbos
Postby BC847 » Sat Sep 10, 2016 6:26 pm
I've run that HT3B for eight years. It was originally paired with a well seasoned HX35 Hybrid. Then went to a 62/65 S300 four or five or so years ago.
Postby spencerdiesel » Sun Sep 11, 2016 9:57 am
Are you still running 2 teeth advanced BC?
H1C/18
Muffler delete
spencerdiesel
Postby BC847 » Sun Sep 11, 2016 7:29 pm
spencerdiesel wrote:Are you still running 2 teeth advanced BC?
Yes, but only so I can pull the IP back from the engine head. ;)
Postby BC847 » Wed Sep 14, 2016 9:09 am
Stupid radiator!
Postby DMan1198 » Wed Sep 14, 2016 1:52 pm
I know right. What's yours doing?
Postby BC847 » Wed Sep 14, 2016 4:03 pm
Dripping. Bottom, driver's side where the core runs into the end-tank. I'd be a bold-faced liar if I said I've changed the antifreeze in the last couple/three years.
. . . . . DOH!
Postby DMan1198 » Wed Sep 14, 2016 6:50 pm
Ahh that's crumby. Mine just has an insulating layer of calcium or whatever, so it runs warm all the time. Sat leaking coolant from the lowest water pipe connection for the two and a half years while it didn't run, so it does have some new coolant.
What do you think you'll do to fix it?
Postby BC847 » Sun Sep 18, 2016 8:51 am
DMan1198 wrote:What do you think you'll do to fix it?
Mishimoto, or what ever it is.
Postby PToombs » Sun Sep 18, 2016 4:42 pm
BC847 wrote:Mishimoto
Ah, sooooo!
Postby BC847 » Sun Sep 25, 2016 12:01 pm
It appears the radiator was sitting heavy such that where those lower two mounts, that long plate they sit on of the radiator itself, is pushed up. The lowest driver's side core coolant passage is bent up and where it connects to the end-tank leaks.
The passenger side, not as much . . .
Hmmmmmm . . . . . . . . ?
Postby fatty » Sun Sep 25, 2016 12:40 pm
Your frame is tweaked from all those 25 psi launches.
Postby BC847 » Sun Sep 25, 2016 5:12 pm
:shock:
Postby BC847 » Mon Oct 03, 2016 5:49 pm
So, does anyone have any information regarding the internal runner diameter of the various T3 12V exhaust manifolds? In the VE fueled world, enormous is not always better.
