mmK.
I finally got to it myself though I didn't mess with the timing light to see what's going on where . . . just yet.
Anyhoo. Folks if you've been keeping up, RCCUMMINS89 & crew have been whittling on some metal based on our discussions here. He's been kind enough to have me included in the development of the thing.
So they carved out a chunk of iron such that it includes:
- The pocket that the timing piston's spring would sit in, in the KSB assembly, less the KSB circuit.
- Said pocket's been made deeper than the OEM design so that one might gain the potential increase in timing device stroke, similar to that the
M&H Timing Spacer affords.
- An adjustable shim for the timing piston's spring. Such allows altering the pre-load of the spring by way of an O-ring sealed bolt that moves a spring retainer.
The adjustment bolt includes a jam-nut to lock it:
The spring retainer nests in the end of the spring and is supported/located by the adjustment bolt in the pocket:
Remove the KSB assembly and slip that boy in there. (I included well over an eighth of an inch of spacers to help get it in better range, based on your comment about wishing you added more)
I then installed a NON KSB case-pressure regulator in place of the KSB type regulator:
With an 850 engine RPM, the original regulator presented with about 60PSI case pressure. Installing the NON KSB regulator had it initially present with about 50PSI. Watching the case-pressure gauge, I adjusted (tapped) the regulator so that I now have 75PSI at 850 engine RPM. On flat -level highway, in 2nd gear, and bringing the engine up to about 3200 RPM, has the case-pressure at about 140PSI. I think I'll have to run a stiffer spring if I want to go higher.
Stabbing the pedal to WOT has the case-pressure drop about 25PSI (I think. It was dark outside, and the gauge is under the wiper-blade. I'm having to shine a flashlight on the blame thing to see it. Work with me. Somebody's got to drive.
I'll have to play with it over the next few days. Gonna be going to the beach again Friday so I'll get to see how it can tame over-advanced timing at highway speeds (1800 ~ 2100 engine RPM).
So far so good though.
