Just a little more . . . . .
Postby DMan1198 » Sat Oct 22, 2016 11:12 pm
I think it might've just been on the .7 gated housing. The actual actuation lever hit a cast boss on the outside of the housing, and it'd stop it from opening fully.
Postby BC847 » Mon Oct 24, 2016 5:30 pm
Got the Stainless Diesel exhaust manifold. It's a substantial, quality piece.
I am a little disappointed with the inlet ports in that they are simply rectangular ports machined into the round runners. The machine work appears to be in a single pass. They don't blend into the runners. The majority of them present with a notable bump where they transition.
I'll have to clean them up (blend) with a burr. :?
Postby dazedandconfused » Mon Oct 24, 2016 5:34 pm
David off topic but what where your 1/8th mile times with the old setup?
Postby BC847 » Mon Oct 24, 2016 6:25 pm
dazedandconfused wrote:David off topic but what where your 1/8th mile times with the old setup?
8.05 best average @ 6400lbs @ 250'.
Postby DMan1198 » Wed Oct 26, 2016 4:30 pm
Wow, I'd never seen the inside of a stainless manifold. They're quite a bit smaller than the ports on the steed speeds.
Postby BC847 » Wed Oct 26, 2016 5:09 pm
A lot of that is the crap I've got to cut away. :(
Postby fatty » Wed Oct 26, 2016 8:06 pm
If it were me, I'd just leave it how it is. I really doubt there will be much difference. But then, I am a bit lazy on things like that.
Postby matthewh » Fri Oct 28, 2016 4:33 pm
Oh, look at all that puuuurty stainless tubing. Awesome find on the doughnuts, never seen something like that before, usually just deal with 180* bends.
What's your reasoning for wanting 14ga tubing versus standard 16ga stainless exhaust tube? What's your plans for welding it all together?
And an fyi, I still have access to the laser table and brake press here at work, so if you end up needing some one off plate or something made up you can't find lemme know and ill see what I can come up with
matthewh
Postby BC847 » Fri Oct 28, 2016 7:06 pm
fatty wrote:If it were me, I'd just leave it how it is. I really doubt there will be much difference. But then, I am a bit lazy on things like that.
Nah. I'm pretty-much anal about the little details. 10 little .1 things adds up to, . . . well, . . . one. :lol:
I purposefully didn't go with the likes of the fine Steed-Speed unit as I figure our mess doesn't wind-up enough to warrant the larger runners. In fact, with our lower revving VE fueled mess, with more normal driving, I'd lose some thermal efficiency in that there'd be unnecessary expansion of the exhaust gases in the manifold that could be better utilized in the turbo(s). Keep the heat in the gases. ;)
matthewh wrote:Oh, look at all that puuuurty stainless tubing. Awesome find on the doughnuts, never seen something like that before, usually just deal with 180* bends.
My thinking with the SS hot stuff is the fact that SS conducts approximately half that of mild steel. Keep the heat in the gases.
The donuts are to accomplish the sharp turn coming out of the secondary and the WYE feeding the primaries. The typical mandrel-bent tubing sports a larger bend radius than I'd like to use. There's apparently an industry standard that identifies the tube size / bend center-line radius. And I can't remember any of it at the moment (see note below). Any-hoo, the typical mandrel-bent tubing get really thin on the long-side, with really tight bends. The donuts are two plates, stamped, cut out, welded together affairs with uniform wall thickness. They should be handy for a number of off-the-wall angle turns.
(These are NOT the stupid expensive articles readily found on the interwebs).
On that note, it appears most ALL those donuts readily found on the interwebs are from the same maker and they sport 14 gauge construction. Digging much further on the interwebs finds at least one reference to some 16 gauge units available over in Europe. The ones I got are MUCH less expensive compared to that most seen. I got'em off Ebay. I figure, they're either the 16 gauge European units, or blemished units from the expensive fellas. I drilled a small hole in one of them to try and see the size. Ehh. I'll have to measure it when I cut them.
I prefer the heavier 14 gauge for the better long-term strength though the primaries will be independently supported. I'll have a four inch long, 3" SS sleeved/bellow type expansion-joint next to a 3" V-band clamp in the hot-pipe. This should accommodate most longitudinal and torsional loading due to thermal cycling.
It's ironic that the 304SS is subject to intergalactic metallurgical fkcu-ups beginning in the temperature range our EGTs commonly operate in. This same issue is seen in the outermost section of the typical heat-affected-zone of welds in 304SS. It seems the chromium tends to precipitate out and convert into an other element and galactic ionization ensues (see note below). High temperature annealing in a controled environment fixes it.
Shit.
I've got a Miller inverter type TIG welder (and yes, I'll be purging). ;)
I appreciate the offer of shop/machine time. I'll keep it in mind. 8)
I get pleasure in hand-crafting stuff.
NOTES:
1- I'm at the beach.
2- My reference/engineering books are at home (though I do have a copy of Mark's Handbook next to the throne here at the beach. Seriously).
3- Been "Drank'in" a bit.
Postby BC847 » Sat Nov 05, 2016 6:20 pm
MUCH mo'betta.
Postby fatty » Sat Nov 05, 2016 6:34 pm
That does look quite a bit better. How many hours you got into it?
Postby spencerdiesel » Sat Nov 05, 2016 6:51 pm
Cleaned up nice!
H1C/18
Muffler delete
spencerdiesel
Postby BC847 » Sat Nov 05, 2016 6:56 pm
fatty wrote:How many hours you got into it?
Three ~ four hours. I bet half of it was waiting for the compressor to build some pressure (I need a new compressor :roll: ).
Postby BC847 » Sat Nov 05, 2016 7:10 pm
I'm gonna include a 1" divided spacer between the exhaust manifold and the secondary. The exhaust manifold exit ports match that of the spacer. The turbo exhaust housing ports on the other hand . . . . ..
More pics tomorrow. ;)
Postby BC847 » Sun Nov 06, 2016 6:10 pm
MUCH mo'betta . . . .
