Over the last couple or three weekends driving to the coast and back, I've been toying with the static timing combined with the spacer gizmo.
After the remnants of a tropical storm, another weekend at the beach, and a couple of evenings of violent storms, I finally had an evening available while I still had some steam in me.
I've actually tried messing with the truck a couple of times this week but with the warmer outdoor temps combined with apparently well advanced timing, my daggum engine cooling fan has been kicking in and running constant. I tried running it up one time while the fan clutch was engaged. Literally smoked the serpentine belt.
Anyhoot, It was a little cooler this evening.
- With 12psig input fuel pressure, the case pressure regulator set to 75psig @ 800engine rpm, has the case pressure level off to about 130 ~ 135psig @ 3200 engine rpm (no load / free-rev).
- Raising the input fuel pressure to 16psig has the 800rpm case pressure rise to 76psig, and rise to 140psig @ 3200 rpm (no load / free-rev).
- Adding to the above, clamping-off the IP's overflow restriction line presents with no difference at 800 rpm, but the case pressure rises to about 145psig @ 3200 rpm (no load / free-rev).
- I noticed that the case pressure went from 75psig @ 800 rpm, to about 120psig by 2200 ~ 2400 rpm. The increase in case pressure from that point on up to 3200 rpm was much slower.
- Doing a couple of 15 psig or so boosted launches and running it on up to 60mph or so saw the case pressure at about 110 when I hit it, and then rise to about 130psig by 3400 or so rpm. With it wound up and letting off the throttle, one saw the case pressure jump on up to 130 ~ 140 before the engine unwound. These injectors clearly tax the thing.
- Baking off the static timing as I have, in an effort to dial in things including the spacer gizmo, has the heap smoke pretty heavy with leaning into the throttle with no to low boost.
I'm wondering if my cooling fan's thermostatic-clutch has gone bonkers and is now a little too tight, meaning it engages a little too early. With the static timing up toward that which the heap historically runs good at, the daggum fan is fully engaged with regular no load highway driving with outdoor air temps as low as 60ish *F. All the while the engine temperature gauge never budges from the typical half-way of the gauge.
