fatty wrote:Boy, you sure don't waste any time. Getting right after it.
fatty wrote:If it were me, I'd just leave it how it is. I really doubt there will be much difference. But then, I am a bit lazy on things like that.
BC847 wrote:fatty wrote:If it were me, I'd just leave it how it is. I really doubt there will be much difference. But then, I am a bit lazy on things like that.
Caution is advised.![]()
Still might wanna check your mess. While ordering parts, I had one vendor include the divided manifold-to-turbo gaskets. Something didn't look right, . . . . . . I ordered a second set from another vendor. WTH!?
First set top, second set bottom. See something?
Here's a second view . . .
I wonder what damage could have been done had I not caught that, and had the hot exhaust gases cut that extra off, and let it into the turbine. I'm not sure that's a T3 gasket.
RCCUMMINS89 wrote:Simply out of curiosity, did you hold both of those gaskets up to the manifold and the turbo inlet?
From my experience the gaskets are much larger than the actual openings. I know my 62fmw T3 .70 housing, is like 1/4" smaller than the gasket all the way around..... both straight from Borg at the time.
Just curious.
