More PAWR without more fuel?
Re: More PAWR without more fuel?
Postby ellis93 » Mon Aug 01, 2011 8:10 pm
12,14,Or 16 are bolt on. Wastegated or not. Only thing is, with the w/ged housing, you'll have to move the down pipe back one inch. The d/p will be close to the fire wall insulation but will clear and not burn the insulation. This will require you to unbolt the hanger/pipe clamp on the bell housing. 100% bolt on ;)
Postby Diesel » Tue Aug 02, 2011 1:02 am
Yeah Im leaning toward 16 non waste gated just so i don't choke off the engine and also not really increase egt's when I've got a load. 21 just seems better suited for a genset than a street vehicle.
1991.5 D250 Intercooled A518
Diesel
Postby Tacoclaw » Tue Aug 02, 2011 7:23 am
Unless you've got future plans of cranking the pump up (Don't we all?), a 12cm housing will do exactly what you want.
You've got an intercooled truck at stock fuel levels. A 16 just seems like a waste of $$ to me. ..
Postby 1arock » Wed Aug 03, 2011 12:10 pm
I put a 12cmwg housing on my 92 auto off of a 94 or 95 and it was an amazing difference in spooling time. It didn't even act like the same truck. The 12cm is just a little longer to the rear because of the wastegate. If you bought one of the nonwastegated short housings it would be a bolt on. If you don't tow heavy I would go with the 12.
92W250 w/a 68D100 skin,tach, pyro, boost, trans temp guages, rebuilt a518 w/a PTC converter, 4in muffeled exhaust, 3200 gov spring, he351cw,M@H dynamic timing, 5x12s,M@H M3 pin, pump jacked with, 3.54s, 6+ lift, 14.5x36r rubber,nearly done,"What was I thinking?"
1arock
Postby Diesel » Wed Aug 03, 2011 8:06 pm
1arock wrote:I put a 12cmwg housing on my 92 auto off of a 94 or 95 and it was an amazing difference in spooling time. It didn't even act like the same truck. The 12cm is just a little longer to the rear because of the wastegate. If you bought one of the nonwastegated short housings it would be a bolt on. If you don't tow heavy I would go with the 12.
Nice. Did you have it installed on a stock fuel setting? If I occasionally tow a single car trailer would that be ok? I'm talking about towing twice a year. I mainly load down the bed.
Diesel
Users browsing this forum: No registered users and 66 guests
