another 14mm pump
Re: another 14mm pump
Postby dazedandconfused » Fri Dec 16, 2011 9:43 am
f100 cummins wrote:i was just curious if i keep enough pressue to the pump and have big enough injectors will the pump live or will it eventually die
I'm not sure on Jason's setup but I know KTA was running a A1000 with a boost referenced regulator and dual feeding the pump. I believe he was or is running a 6x16 or 6x18.
Postby JQmile » Mon Dec 19, 2011 9:23 pm
Mine's an AirDog 165 set at 30psi with a loctite front seal and Hellmann sump.
JQmile
