Hamilton Cam's Head
Re: Hamilton Cam's Head
Postby collegekid » Fri Nov 04, 2011 6:25 pm
:D
collegekid
Postby Kasper Cummins » Fri Nov 04, 2011 6:34 pm
Mark Nixon wrote:If you're freehand porting, without a flow bench, you're wasting your time.
Even if you made a smoother path it would increase air flow. Before you start porting on a good head test your skills on a juck yard head. Even with a good freehand porting job it not going to be a huge difference but I could help.
I would do the cam until the head is a proven upgrade.
92 W250 club cab
Kasper Cummins
Postby KTA » Sat Nov 05, 2011 6:46 am
My only concearn about this head would be what they have done on the swirl part. A decrease in swirl would be bad for making power especially at low rpms. That isn't as much an issue for a high rpm competition motor like what these were made for. One of the reasons a p-pump 24v usualy sucks on power and torque is the decreased swirl from the cylinder head. vs the 12V. I think a VE with a decent set of twins would beat a VE with one of these heads and a single turbo across the board on power. Now a hamilton head with twins might gain you a little, but again you might have to change injectors and timing a lot to make it work. :P Even then if the swirl is decreased much over stock you may not ever get what the stock head can do. Only a dyno could really prove the gains or losses. I vote you try it back to back with only the head change and let us know the results. 8)
Postby Tacoclaw » Sat Nov 05, 2011 8:11 am
Thanks for the thoughts. As much as I'd like to go balls-out on this thing, I'm probably going to grab the cam. My only real worry is that if I do end up wanting more, that the cam combined with the head will "over-air" my engine. Only one way to find out I guess. :grin:
KTA wrote: Only a dyno could really prove the gains or losses. I vote you try it back to back with only the head change and let us know the results. 8)
Alright, you talked me into it.
Now accepting donations! All proceeds will go towards replacing lost bolts and thrown tools during the testing process.
minimum $3,000.00 donation amount
8)
Postby mike8061 » Sat Nov 05, 2011 10:21 am
"One of the things we are seeing is that swirl changes quite a bit with valve angles. Also, the more we raise the roof, air starts to enter the cylinder on all sides which slows swirl. As the intake port roof is as cast, the air favors the side of the valve on the exhaust side. When it enters it hits the wall of the cylinder at a slight enough angle that it induces a good bit of swirl. The 24v has almost half the swirl of the 12v, and our head in stock fashion, is just behind the 24v. One cool thing we are seeing is that at .675" both swirl and flow peak. Cam profile will be super important to making power with this head knowing what the port shape dictates. That is a .381" lift intake at the cam if a 1.7 rocker is used.
Different pistons and more attention to timing and injector/piston interaction is going to be very important power bands are about to be shifted!"
Quote from Zach on Comp D
Would seem to go with KTA's point of low RPM power loss due too lack of swirl. Perhaps for the VE a better rout would be to spend the money on an intake and some minor porting/smothing? Only a test would show for sure!
92/93 W250 Ext. Cab. LP lift pump, 3200 spring, fuel screw maxed, pin almost ground through, 6" lift, flat bed, 35x12.5, big bumper
93 ext cab parted
92 reg cab parted
1967 C50 swapping in spare 5.9 auto and 205. 8.10 low in rearend. should pull somthin
mike8061
Postby oldestof11 » Sat Nov 05, 2011 1:50 pm
He does say that the low RPM swirl is not good. The major part where it shines is high rpm/high valve lift which is nice for weekend warriors/DD. Towing I can see being majorly disadvantaged by one of these heads.
Postby ahale2772 » Sun Nov 06, 2011 11:19 am
agreed, some of the flow numbers they are getting are at 2wice the normal valve height of what normal trucks run.
levi, im going with the cam too, not too excited about trying to replace lifters in the truck :(
mmmmm Air flow :grin:
Postby shiftycapone » Mon Nov 07, 2011 10:33 pm
KTA wrote:My only concearn about this head would be what they have done on the swirl part. A decrease in swirl would be bad for making power especially at low rpms. That isn't as much an issue for a high rpm competition motor like what these were made for. One of the reasons a p-pump 24v usualy sucks on power and torque is the decreased swirl from the cylinder head. vs the 12V. I think a VE with a decent set of twins would beat a VE with one of these heads and a single turbo across the board on power. Now a hamilton head with twins might gain you a little, but again you might have to change injectors and timing a lot to make it work. :P Even then if the swirl is decreased much over stock you may not ever get what the stock head can do. Only a dyno could really prove the gains or losses. I vote you try it back to back with only the head change and let us know the results. 8)
So how about a vp pumped 24v? Dynamic timing could make the difference but a low static timed p pump would/should produce similar results down low. My p-pumped 24v made good torque with both the vp and p pump, along with 700hp with a "small" set of injectors. Just questioning your logic here, I am curious. I have another 24v head in the garage, but the debate over 12v or 24v for the next motor continues...
1990 D250
shiftycapone
Postby KTA » Tue Nov 08, 2011 8:37 am
The higher injection pressure of the VP combined with the fewer and smaller holes of the injector make the less swirl work. Making 600rwhp with a VP is not terribly difficult and it is still very streetable and tuneable at that level. Power levels beyond that with a VP are difficult to obtain as the pump doesn't have the capacity for it. Running small injectors with athe p-pump helps as it increases the injection pressure to more like vp pressures, but if you go all out and run big nozzles with a big p-pump it becomes a problem. I know in dyno testing Haisly had done on a 3.0 motor trying various timings and nozzles the 24V with the same cam, compression, pump and turbo was down 75-100hp over the 12V on a 1100-1200hp motor.
Postby shiftycapone » Tue Nov 08, 2011 4:55 pm
KTA wrote:The higher injection pressure of the VP combined with the fewer and smaller holes of the injector make the less swirl work. Making 600rwhp with a VP is not terribly difficult and it is still very streetable and tuneable at that level. Power levels beyond that with a VP are difficult to obtain as the pump doesn't have the capacity for it. Running small injectors with athe p-pump helps as it increases the injection pressure to more like vp pressures, but if you go all out and run big nozzles with a big p-pump it becomes a problem. I know in dyno testing Haisly had done on a 3.0 motor trying various timings and nozzles the 24V with the same cam, compression, pump and turbo was down 75-100hp over the 12V on a 1100-1200hp motor.
Very interesting. I only ask because Ron Allen just did 1218hp on a p-pump 24v with a very mild head, and drove it home 2-3 hours to boot.
1990 D250
shiftycapone
Users browsing this forum: No registered users and 63 guests
