5x18s....
Re: 5x18s....
Postby ahale2772 » Tue May 01, 2012 1:29 pm
Soggy, ever dyno that setup? I finally ordered a 63, so Ill be deciding on injectors very soon
EDIT.... would help if I read your post all the way... anyways, how does it run with a 63 and 5x18's?
Re: 5x18s....
Postby soggy » Tue May 01, 2012 3:28 pm
Here is short run. http://www.youtube.com/watch?v=FknFATLtB7w
It runs strong and spools good, I have a fletcher DP3 cam so that helps a lot. I went with the .88 non divided housing to save 100 bucks, but I've heard the .91 divided spools better. With how mine is setup at 45 psi it does not give enough air. What are the details on your turbo?
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Re: 5x18s....
Postby ahale2772 » Wed May 02, 2012 6:41 am
well now that you reminded me that .88 is undevided... UGH... I thought .88 was divided,
anyways, ungated, extended tip 63/68/.88
Re: 5x18s....
Postby soggy » Wed May 02, 2012 10:10 am
Yep, same as mine, should work pretty decent.
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Re: 5x18s....
Postby ahale2772 » Wed May 02, 2012 3:19 pm
hoping to get a .91 divided housing for it, i hear it will spool better even if it is a tid bit bigger
