tow rig/ dd questions
Re: tow rig/ dd questions
Postby RCCUMMINS89 » Tue Apr 16, 2013 2:55 pm
I know, even now I forget about that often. But, I had an 03 HO 6 spd. w/leveling kit, 35s, edge tuner, 90hp nozzles and some exhaust. Had the power to pull 50k pounds if need be and never had to worry about egt problems, only engine temps.
Postby rockbuggy4x4 » Tue Apr 16, 2013 3:19 pm
Sutter1stgen wrote:If I could run a piston lift pump i would. My power goals were not realistic with a mechanical pump though. I like the fact that you can rely on the mechanical lift pump in almost every scenario. Alternator goes out you can still get home. I'd chose mechanical over electric any day.
Huh that's funny Eric. I would have never thought a common rail would do that. And no I'm not kidding.
Very true. That happened to me once, all I needed was a jump start. I don't see me going above 400hp anytime soon, that'll save me a little green stuff. lol So if I get that lift pump, I would need to get a different spring. Is that easy to do yourself, or should I look for one that is ready to go?
rockbuggy4x4
Postby RCCUMMINS89 » Tue Apr 16, 2013 3:40 pm
Depends, I'm the only one that offers the lift pump that we are talking about. Others have the smaller diameter piston.
The kit I sell is ready to bolt up and run. I set the pressure on them to run with the ve.
If you bought a factory 2nd gen piston lift pump, you'd have to use a different regulating spring (I also sell those on my site) and then piece together the rest of the kit (hard line, spacer, and some gaskets).
Postby oldestof11 » Tue Apr 16, 2013 4:47 pm
Fwiw, i would get s good mechanical lift pump. Air dog and fass ate both having problems with keeping motors in those things.
Postby Sutter1stgen » Tue Apr 16, 2013 9:15 pm
^^^^ don't tell me that. I just got done installing my AD II 165. I was really hoping it would stay together.
Eric
Sutter1stgen
Postby rockbuggy4x4 » Wed Apr 17, 2013 7:01 am
I'm not going to be buying any parts for my truck just yet, but when I do, I'll definitely get that mechanical lpplp kit off your site RC. Probly going to wait another month or so. That way I can buy most or all the parts I need at once and they won't be sitting at my house for as long. That's good to known about the airdogs and fass pumps. I know it's preferred to upgrade the fuel lines and the draw tube (or add a sump) with the electric pumps. Is it the same deal with the lpplp?
rockbuggy4x4
Postby RCCUMMINS89 » Wed Apr 17, 2013 7:21 am
By increasing the size of the supply lines and draw tube, you'll increase the flow of the pump. In short, you won't be able to draw the pressure down as far at wot.
Postby rockbuggy4x4 » Wed Apr 17, 2013 8:02 am
Yea, that's what I figured.
Jimmy
--> '95 jimmy not so stock
rockbuggy4x4
Postby RCCUMMINS89 » Wed Apr 17, 2013 8:08 am
What else on the goodies list do you plan on getting before the lift pump? Doing everything, or at least most at one time is the correct way to do it.
Postby dazedandconfused » Wed Apr 17, 2013 8:33 am
Sutter1stgen wrote:^^^^ don't tell me that. I just got done installing my AD II 165. I was really hoping it would stay together.
Hopefully you filled out and sent in your warranty card.
Postby rockbuggy4x4 » Wed Apr 17, 2013 9:06 am
Well, I'll need injectors since mine are the stock 9mm. Was going to pull the head off to check the cylinders and make sure everything looks good. And while it's off, I'll get it ported, install 60# springs, and O-ringed. A 3 piece exhaust manifold, fuel pin and 3200 spring for the IP, 7.3 PS IC, and a built 47rh. And of course, LOTS of gauges. lol I believe there's less than 250k miles on the engine, so I'm not sure if I am going to get a cam or just run the stock one and see how it turns out. I'm probly missing a few things.
Jimmy
rockbuggy4x4
Postby Sutter1stgen » Wed Apr 17, 2013 9:08 am
Opened packaging and installed on Sunday. I'm sending it in today. Says I have a month to turn it in from purchase. Didn't know that because packaged was closed. Hopefully they understand.
Eric
Sutter1stgen
Postby RCCUMMINS89 » Wed Apr 17, 2013 9:19 am
rockbuggy4x4 wrote:Well, I'll need injectors since mine are the stock 9mm. Was going to pull the head off to check the cylinders and make sure everything looks good. And while it's off, I'll get it ported, install 60# springs, and O-ringed. A 3 piece exhaust manifold, fuel pin and 3200 spring for the IP, 7.3 PS IC, and a built 47rh. And of course, LOTS of gauges. lol I believe there's less than 250k miles on the engine, so I'm not sure if I am going to get a cam or just run the stock one and see how it turns out. I'm probly missing a few things.
Sounds like a good plan to me.
Postby ellis93 » Wed Apr 17, 2013 9:22 am
Sutter1stgen wrote:Opened packaging and installed on Sunday. I'm sending it in today. Says I have a month to turn it in from purchase. Didn't know that because packaged was closed. Hopefully they understand.
I wouldn't sweat the whole not holding up stuff. I've installed several of them with absolutely zero issues.....BUT they also are not molested either. In other words,I'm not needing them to pump 30 something pounds to fuel some monster. These are work horse trucks pimpin VP44 time bombs.
Postby Sutter1stgen » Wed Apr 17, 2013 9:35 am
Thanks I needed to hear that.
Eric
Sutter1stgen
