Gear Vendors
Re: GV Build
Postby flashgordon » Fri Feb 01, 2008 10:15 am
Ace wrote:I did a beef-up on the GV sump/filter with the power steering resevoir from Mack truck. Has a built-in filter. I'll post some pics when I get a chance. GV sump holds over 5 quarts now.
Should be able to run for years now between oil changes, no worries. :shock:
:wrench: ace, i wouldn't mind seeing them pic too ;)
flashgordon
Postby DTanklage » Fri Feb 01, 2008 10:49 am
thats a great idea, would like to see the pix
DTanklage
Here they is...
Postby Ace » Fri Feb 01, 2008 1:47 pm
http://stuff.is-a-geek.net/PhotoAlbum/C ... TD_125.jpg
http://stuff.is-a-geek.net/PhotoAlbum/C ... TD_126.jpg
That resevoir holds a bit over 3 quarts and there's a little filter inside. Found it on eBay. It looked like it was from a 60s, maybe 70s era rig. Guy said the part# ref'd some model Mack truck, PS reservoir. I was happy to learn Wix even still makes the filters. I figure I'll run it a couple years, drain the reservoir, change the filter and re-fill. The pump runs off the same circuit as my tranny filter:
http://stuff.is-a-geek.net/PhotoAlbum/C ... CTD_62.jpg
The pumps have switch on the dash and I run them for 15 or 20 minutes at a time on long drives after they get warmed up every couple weeks or so.
Ace
Postby PToombs » Fri Feb 01, 2008 4:26 pm
Mid '80's Diamond Reo uses the same thing. Buddy has 2 of them. You did plug the filler hole right? Or have the dipstick for it? ;)
Postby DTanklage » Fri Feb 01, 2008 9:51 pm
thats really cool
what kind of pump can pump that 90 wt?
even warm that stuff is thick
DTanklage
Postby Ace » Sat Feb 02, 2008 6:34 am
PToombs wrote: You did plug the filler hole right?
Dang! Now I know why I have to keep filling it up!! :o
No, the dipstick is long gone and the hole it used to occupy permanently sealed. Despite being rated at 90W, Syntorq fluid flows really well. The pump is just an old style autopulse fuel pump. Seems to do fine for the simple task of circulating the fluid on an occasional basis for short periods.
Ace
Postby DTanklage » Sat Feb 02, 2008 9:33 am
i ran that stuff the first time round. my unit shifted way too hard. was a chore to drive. this time i put sta lube syn in it. outta a 5 gal drum that was at my buddies shop. shifts a lot smoother now. oh, and even with the stock deep sump on it i only change the fluid once a year. is that not often enough? i am not that worried about wear. i have a friend that will rebuild it for me for free when it wears out. so far i have beat the crud outta that thing with no probs
DTanklage
Postby Ace » Sat Feb 02, 2008 9:56 am
I suppose they are practically indestructible as long as you keep good oil in them. Problem is, it only holds about one and half quarts. I think a yearly change would be plenty. GV recommended interval is 5,000 mi. but they don't say if that refers to conventional or synthetic fluid.
Odd you mentioned the hard shifting w/Syntorq. That is the fluid GV is recommending now for SMOOTHER shifting. But I think you can run just about any gear oil in it and it'll do fine if it gets changed. The main reason I upgraded the sump is just so I don't have to worry about that too much. Got plenty other stuff to worry about...
Ace
Postby DTanklage » Sat Feb 02, 2008 12:29 pm
maybe it wasnt syntorque?
dunno, what ever they recommended 2 yrs ago or so, when i got the unit
thick stuff, what ever it was
actually, i think you are right - they rec the sw to that stuff later
i have never ran it - wonder how it compares to the sta lube?
DTanklage
Postby Ace » Sat Feb 02, 2008 2:36 pm
Mine is just now a year old, and the Syntorq spec was an addendum (extra page stuffed in) to the manual. The stuff is VERY good, but very EXPENSIVE, as well. It's rated 75w-85w, and is basically a full-syn GL4 synchromesh fluid. Looks to pour more like a light motor oil, to me. $15-$20/qt. depending on source.
Ace
Postby DTanklage » Sat Feb 02, 2008 4:23 pm
good thing it only takes a couple of qts then
that is what the sta lube syn is rated
something like that
75/85 - pours thin
you know, 20 yrs ago they were telling ya to put atf in those things
DTanklage
Postby mhuppertz » Sat Feb 09, 2008 9:34 pm
My GV is burned up, no shift into OD. Have any of you guys found rebuild parts for one?
mhuppertz
Postby DTanklage » Sat Feb 09, 2008 10:07 pm
sure its not just a bad solenoid?
DTanklage
Postby mhuppertz » Sun Feb 10, 2008 9:01 am
DTanklage wrote:sure its not just a bad solenoid?
Not totally I guess. I called GV and explained the situation they told me the clutches were burned up (thanks to the guy my nephew got it from!) and that I would need to send it in for a rebuild exchange, $750 large. That ain't happening any time soon.... :(
mhuppertz
Postby DTanklage » Sun Feb 10, 2008 10:06 am
send it to my buddy in oregon
jeff marsh - marsh transmission
actually, sent it to his smaller shop closer to his house
hamby trans
tell him tank sent ya
503 885-8852
800 276-5768
i think the first # is hamby trans. if not the 800 # is marsh trans and they will give you hamby trans
jeff is as cool as they come
DTanklage
