OPeration - "guaranteed to blow up"
Re: OPeration - "guaranteed to blow up"
Postby DMan1198 » Wed Apr 30, 2014 7:00 am
Yeah. After the pump pulses the pressure in the line drops. With bigger lines that pressure drop becomes more noticeable (engine lopes) as the pulse takes longer to repressureize the line. At least that's my understanding of how someone explained it
Postby DodgeFreak » Wed Apr 30, 2014 10:01 am
PToombs wrote:
oldestof11 wrote:You have more "squish" so in theory you have less strain on the rotor.
What "squish"? Rule #1 of hydraulics, fluids don't compress, that's how hydraulic systems work. ;)
They don't compress but once the injector fires you have a drop in pressure and then fill time. Take a straw fill your mouth with water put your finger over the straw and blow as hard as you can then remove your finger for a split second and cover the straw again. You will feel the drop in pressure and the fill time.
Postby DodgeFreak » Wed Apr 30, 2014 10:05 am
Also in the world of hydraulics its all a closed system. Meaning if you want to use a cylinder the fluid going into the base end is dead headed no where to go. In an engine its more of a semi open system where it builds pressure till it releases and then repressureize\refill.
Postby PToombs » Wed Apr 30, 2014 4:10 pm
Ok, I see where you are going. The bigger lines deliver more fuel, but in your application because of bleed off it causes the lope due to the refill time.
Postby Kasper Cummins » Tue Jun 17, 2014 7:30 pm
So since its been slow on this site I'll dig this one up.
Do you have it done or are you waiting on larger lines?
92 W250 club cab
Kasper Cummins
Postby RCCUMMINS89 » Tue Jun 17, 2014 7:57 pm
I'm not going to run larger lines..... I was going to have a builder put it together for me, as the "donor" pump is blown to bits. But seeing is how there was going to be like a fifty billion month wait time... I'm just going to do it myself.
It'll either run or not within a week (hopefully). I have everything back to me as of today.
Postby Kasper Cummins » Tue Jun 17, 2014 8:11 pm
I have a parts pump that I take apart and put back together to get a better understanding on how it work. The head and rotor look simple to swap but I've never had to put it back together and make it run. Good luck, take pictures I'll post them for you if needed.
92 W250 club cab
Kasper Cummins
Postby RCCUMMINS89 » Tue Jun 17, 2014 8:13 pm
Yea, the h/r part is super easy when comparing to taking an entire pump apart and eye balling to see if things look good or not.
Postby RCCUMMINS89 » Sun Jun 29, 2014 10:18 pm
Update.... still haven't had time to build a pump yet.
Postby PToombs » Mon Jun 30, 2014 6:23 pm
Oh. :( I thought you were going to tell us you blew it up! :lol:
Postby 93flatbed » Thu Jul 03, 2014 7:54 pm
I thought I was going to see a 1k/2k dyno run...
93flatbed
Postby RCCUMMINS89 » Thu Jul 24, 2014 8:26 pm
UPS lost something that was going to be used..... grr.....
Postby RCCUMMINS89 » Wed Aug 27, 2014 2:24 pm
Update....
Everything is here and ready to go together. However, due to it being so close to hunting season... I'm just not risking the downtime.
It will be done around the first of October.
Postby ellis93 » Wed Aug 27, 2014 2:49 pm
And the "Super Procrastinator" award goes to one Eric Gilbert :lol:
Postby RCCUMMINS89 » Wed Aug 27, 2014 2:53 pm
I know right... 6 month pump build thread.
