Cutting O-rings into the block instead of the head?
Re: Cutting O-rings into the block instead of the head?
Postby Begle1 » Thu Jun 11, 2015 2:15 pm
Machine shop guy wants to use .040" O-rings?
Postby ellis93 » Thu Jun 11, 2015 8:51 pm
They'll probably sink them deep in the surface to make sure they seat well. Sounds reasonable to me.
Postby diesel freak01 » Thu Jun 11, 2015 8:57 pm
That sounds awfully thin to me. Your gasket is prolly around .060. That wont seal the gasket if you put a cut in the head or block. Generally you want 10-15 thou crush on the rings. At least that's what we use on the tractor.
Edit
You can buy rings from sealtec if you have the sizes you need.
1993 d350 ctd drw 2wd auto
diesel freak01
Postby RCCUMMINS89 » Thu Jun 11, 2015 9:14 pm
8 thou protrusion is usually about max.
Postby Begle1 » Fri Jun 12, 2015 6:32 am
So to get 8 thousandths protrusion on a 40 thousandths ring, that'd mean the grooves need to be cut 32 thousandths into the block, correct?
I kinda get the impression that there really isn't a consensus on the best way to O-ring a block.
Postby diesel freak01 » Fri Jun 12, 2015 10:04 pm
This may be the difference in a wet sleeve motor and non sleeved.
diesel freak01
Postby RCCUMMINS89 » Fri Jun 12, 2015 10:48 pm
Fresh back from my o ring guy: .051 SS heat/related wire, usually no more than .012 max protrusion.
Postby Begle1 » Sat Jun 13, 2015 12:47 pm
So does everybody install the O-rings so they press directly onto the outside of the firerings?
Without them pressing directly onto the fire-rings, I don't see how they'd work, considering that the head gaskets I have only have bare metal between every other cylinder and not a constant-thickness fiber?
http://www.enterpriseengine.com/wp-cont ... -Reinz.jpg
Are head gaskets the same for .5mm over pistons as for stock-diameter pistons?
Postby RCCUMMINS89 » Sat Jun 13, 2015 8:58 pm
Installed so that they crush the fire ring (causing a better seal).
Postby Begle1 » Sun Jun 14, 2015 5:36 am
So like dead-center to the firerings or on their outer edge?
Postby RCCUMMINS89 » Sun Jun 14, 2015 9:58 am
From what I'm used to, pretty much dead center of the fire ring.
Postby Begle1 » Wed Jan 20, 2016 5:46 pm
My machine shop has been sitting on this for a year because they're convinced it's not going to work.
So the concept is as follows:
Use a stock, OEM, standard Cummins headgasket.
Cut the groove for the o-ring into the block, so that the ring smashes directly into the center of the firering on the Cummins headgasket.
Press a .040" diameter stainless steel ring into a .040" wide groove .032" deep, for .008" of protrusion.
Postby Begle1 » Thu Jan 21, 2016 3:05 pm
I found my notes.
http://www.competitiondiesel.com/forums ... ght=o-ring
Consensus seems to be to use a .041" O-ring, cutting a groove .038" or .039" wide, .029" to .032" deep and 120mm diameter/ dead center to the stock firering.
That should put .002" crush on the ring into the block, and gives the ring .012" to .008" of protrusion.
I think I'll go with .010" protrusion since that seems to be in the middle of what everybody is saying.
Postby fatty » Thu Jan 21, 2016 6:49 pm
I don't see any reason that wouldn't work.
Postby ellis93 » Thu Jan 21, 2016 7:25 pm
Worked out fine for the junker drag truck on compd
