Fuel pin discussion
Re: Fuel pin discussion
Postby ellis93 » Tue Feb 10, 2015 5:53 pm
Remps wrote:I thought the M2 pin was the same diameter on the bottom, on the cut or uncut side. If so, has the afc top been modified to allow the m2 to come up enough to hold the slide pin in? Looks like you are on track to building a pin that will control that particular irregular pump of yours. :lol: and by irregular I mean the weird smoke issue.
Even with the stop cut out of the pump top you'll never come off the ramp of the m&h pin. I have come close to cutting a spacer out of some aluminum to go between the top and body....like m&h sells.
I'm not crazy,it's doing it :lol:
Last year this same truck screwed me after hauling cows by belching white smoke and running off 3cylinders,for no reason other than valve stem seals. Oil + white smoke = stem seals....that didn't compute either,but it happened.
Postby Remps » Tue Feb 10, 2015 6:32 pm
The spacer would help for sure then. Wouldn't necessarily have to be metal, one could probably use a thick piece of rubber, or cut one out of an old head gasket. Well maybe not rubber for really high boost lol.
Postby DodgeFreak » Tue Feb 10, 2015 6:43 pm
heavy duty mud flap....I really don't have an answer for any of it.....If mine hazed I would try the same stuff you are Ellis just to see.
Postby RCCUMMINS89 » Tue Feb 10, 2015 6:45 pm
These are ALL reasons why we stopped using Denny and M&H pins and solely went with BD. Currently in the process of manufacturing our own. The ramp starts significantly higher than even the BD.
Postby ellis93 » Tue Feb 10, 2015 6:53 pm
RCCUMMINS89 wrote:These are ALL reasons why we stopped using Denny and M&H pins and solely went with BD. Currently in the process of manufacturing our own. The ramp starts significantly higher than even the BD.
I want to know when you have a few ready. I'll buy one just to see what they'd be like.
Postby RCCUMMINS89 » Tue Feb 10, 2015 7:03 pm
Will do.
Postby DodgeFreak » Tue Feb 10, 2015 8:48 pm
I just about pulled the trigger on bd's then the price went sky high....
Postby RCCUMMINS89 » Tue Feb 10, 2015 9:14 pm
Message me, and we can discuss options. I'm not taking away from BD's quality and design. It can be improved, but they currently still have the best fuel pin on the market.
Postby BILTIT » Wed Feb 11, 2015 8:11 am
Yup, i found the BD pin to have much reduced low end smoke than both the dennyT stg 1&2.
Derek B.
BILTIT
Postby AHineman » Wed Feb 11, 2015 10:07 am
Anyone care to post a pic of the bd pin? I always thought it was just a copy of the old smokey pin, but I don't remember ever actually seeing one.
Postby RCCUMMINS89 » Wed Feb 11, 2015 12:54 pm
I'm waiting.... a buddy of mine has a BD pin right next to an M&H stage 3 pin.
Postby DodgeFreak » Wed Feb 11, 2015 4:31 pm
I'll wait to see what you turn out Eric, I'm not in a hurry or anything for one.
what is the point of grinding the afc foot off??? is that to use more of the pin?? I can't find the thread where they ground it off.
Postby BC847 » Wed Feb 11, 2015 5:26 pm
Just for Show & Tell, pics of one while being dialed-in profile wise.
The ramp is too short for the given fuel-pin stroke. This results in additional fueling at idle, as well as it stopping further fuel enrichment before the end of the fuel-pin stroke.
The final adjusted item presents with so much needle stroke that it has the OEM needle go past its O'ring. DOH! :?
The stock/OEM nylon spacer stops that.
Further adjustments would have the cut not be so deep while keeping the ramp placed right (effectively moving the ramp to the right as shown in the image above).
Ends up looking like this . ..
Still too deep though. Nylon spacer fixes it.
Postby RCCUMMINS89 » Wed Feb 11, 2015 5:31 pm
Now a days there are better options than grinding the foot. It will give more fuel on a stock pin... but it also gives more fuel at zero boost.
BC..... Yes, there is zero reason to cut a pin deeper than half way. The darn pin doesn't even come out halfway across the bore.
Postby RCCUMMINS89 » Wed Feb 11, 2015 5:41 pm
Someone pm me an email address.... I don't feel like trying to post pictures :lol: Wife's not home, and I don't know my photobucket account
