P-pump chasin
Postby KTA » Sat Feb 23, 2008 4:46 pm
That is a decent price for an s300g assuming it has the 71mm turbine, as for the s400's that part number usually turns up on ebay for around $700 fairly frequently. If you don't have any luck there I can get them for the prices I listed plus shipping for you if need be.
Postby cummins king » Sat Feb 23, 2008 5:55 pm
there good and there cheaper that was on of my choice for the top turbo but my guy didnt have any, and same with the gt 60
93 4X4 auto
cummins king
Postby SChandler » Sat Feb 23, 2008 6:52 pm
KTA wrote:Once you get your fuel system on including the big injectors all you need is a good nitrous system, its worth 100+rwhp easy.
For a cheap twin setup you can get Schwitzer 169417 s300 for the bottom turbo ($700), and 171702 S400 for the top($650). That setup can support 500-800hp.
How is that for some ingredients. 8)
So, the part number that you listed is for a 71mm turbine S300, right? Do you have the specs for both turbos? Thanks.
SChandler
Postby bgilbert » Sat Feb 23, 2008 8:47 pm
SChandler wrote:So, the part number that you listed is for a 71mm turbine S300, right? Do you have the specs for both turbos? Thanks.
171702 is a s400 2.9 compressor 3.4 turbine 1.32ar turbine housing.
Bill Gilbert
bgilbert
Postby KTA » Sat Feb 23, 2008 8:50 pm
The s300 listed is a 62x71 and the s400 is a 75x88. The s300 can flow about 55lbs/min of air and the S400 flows 90lbs/min. Both are effecient(70%) at pressure ratios of up to 4.
Postby ford69557ci » Sat Feb 23, 2008 9:18 pm
wow i didnt know that the s475 and 62-71 was good for up to 800 hp. Then my 66-77 ans s485 should put me right where i wanna be on no nitrous.
ford69557ci
Postby SChandler » Sun Feb 24, 2008 8:24 am
BGilbert and KTA, thanks for the turbo specs.
I did a google search on both the S300 and S400 part numbers and came up with this place that has the S400 listed for $656.78 with no core charge (http://www.fleetsource.com/Detroit_60_Series_Turbo_p/171702.htm).
I have no experience with them, but the price is probably going to be hard to beat. I didn't find anything on the S300 yet.
SChandler
Postby DTanklage » Thu Mar 27, 2008 8:17 am
thats prolly cuz the truck guys have cornered the market
used to be a 500 dollar turbo
DTanklage
Postby CumminsPride » Thu Mar 27, 2008 10:38 am
http://www.turbosupply.net/bwturbo.html[url] What about these guys?
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby dazedandconfused » Thu Mar 27, 2008 2:40 pm
Very good thread guys, with good info.
Postby SChandler » Thu Mar 27, 2008 2:59 pm
CumminsPride wrote:http://www.turbosupply.net/bwturbo.html What about these guys?
They didn't turn up because I think I searched for Schwitzer and the part numbers. Didn't think to do the search with Borg Warner and the part numbers :oops: . Darn turbo companies making things difficult. Wish those guys listed prices on their website. Also found these guys: http://www.centralturbos.com/pop-werks7a.htm. Don't know anything about either place but it looks like you could order from either one.
SChandler
Postby bgilbert » Thu Mar 27, 2008 3:16 pm
For a s400 171702, you just missed out. HTT had them listed on their website for $625. I called and questioned them, told them I'd take one for that price and found out they raised the price to $750. They said ah shoot when I told em it was still listed for the lower price. He honored it 8) 8) . I see now they've changed the listing to the higher price. Probly gonna be hard to find one that cheap now. Scheid has a s300 62/71 for $995 last I was in there.
bgilbert
Postby CumminsPride » Fri Mar 28, 2008 2:44 pm
They did have the S300 on there that KTA referenced for $795. They recently removed their prices.
CumminsPride
Postby SChandler » Mon Mar 31, 2008 7:04 am
CumminsPride wrote:They did have the S300 on there that KTA referenced for $795. They recently removed their prices.
Well, then I guess I've got a reason to get my taxes done :D .
SChandler
Postby DTanklage » Mon Mar 31, 2008 8:30 am
i just called them and they said nfw
not 795
not 995
if i could get a new 62-71 for 800 bucks i would jump on that deal
he did say he could custom build a 400, to be used as a single, with a 72 turbine and i think he said a 66 compressor for around 1500
that was joe at the indy store
DTanklage
