The 24v timing cover vent used in conjunction with the 1st gen's OEM lifter-valley vent works rather well.
BC847 wrote:I run the A1 stud kit from Haisley Machine. With the typical bottom tapping and cleaning of the bores, I'm able to clear them with removing a small amount of the valve cover's webbing with no problem.
Ace wrote:A regular tap can be made into a bottom tap by carefully grinding the tip down to where the threads even up.
sdstriper wrote:...I prefer a cut-off wheel myself...
