BC847 wrote:
NOTE: I'm led to believe that dropping the pop-pressure a little mimics advancing the injection timing event by allowing fuel flow just that much earlier. The Scheid 6x.016" EDMs are set to 3400.
Then , unless you know your own pop pressure then timing is just guessing. I have no idea what mine are set at. I assume stock pop pressure.
