mileage booster!! long trip to find out!
Postby SChandler » Tue Sep 08, 2009 9:09 pm
T.winegar wrote:so like this: 285/235= 1.21
then
x miles= actual miles
Only if you drive on the sides of your tires. :D 285 is the width of the tire in millimeters. 285 millimeters is approximately 11.2 inches. The theoretical height of the tire is is 32.8 inches. That comes from this formula: 2 x width of tire x aspect ratio / 2540 + rim diameter = height of tire in inches. So, to figure the advertised height of a metric sized tire in inches, it would look like this: 2 x 285 x 75 /2540 + 16 = 32.8 inches. The height that the truck sees is the distance from the ground to the center of the axle x 2. That number will be less than the advertised size due to a number of factors, but mainly due to there being a load on the tire and the manufacturers measuring the tires unloaded.
A 285/75R16 works out to be about 32.8 inches tall from the formula and a 235/85R16 is about 31.5 inches. Thus, 32.8/31.5=1.0413 x indicated miles = actual miles.
SChandler
