Piston lift pump
Postby Bad93Cummins » Mon Jan 25, 2010 9:20 pm
p-pump, I know what the lift pump is.
Bad93Cummins
Postby ahale2772 » Tue Jan 26, 2010 1:04 pm
well the p-pump is capable of alootttt more hp its a very good design used on big motors for years, they can move more volume at a higher pressure
Postby peobryant » Tue Jan 26, 2010 1:11 pm
Bad93Cummins wrote:What does a p-pump do for our trucks?
Our stock lift pumps are barely good enough for the stock output of these engines. The Pistion LP will hold a steady fuel pressure with much higher horsepower numbers. Pete is close to 400rwhp with his piston lp, and I believe he said his barely drops below 10psi with full throttle. I believe he also still has the stock fuel lines.
Don't you already have an electric pump?
Postby ahale2772 » Tue Jan 26, 2010 1:21 pm
im thinking he was asking about the p pump itself not the 2ng gen lift pump...
Postby peobryant » Tue Jan 26, 2010 1:38 pm
ahale2772 wrote:im thinking he was asking about the p pump itself not the 2ng gen lift pump...
:oops: I read that wrong... I thought he said he knew what the P-Pump is, not the piston pump.
Postby Bad93Cummins » Tue Jan 26, 2010 7:53 pm
Yea I already have an air-dog, I was just wandering what a p-pump does for our trucks
Bad93Cummins
Postby Tintacker » Tue Jan 26, 2010 8:15 pm
I guess the biggest difference is a P7100 will push as much fuel and RPMs as you want or, as much as your wallet will allow.
SOLD: :( '92 W250 LE auto PDR 190's, 3200 spring, Skyjacker 2" front springs with Bilstein 5100s
'01 2500 QC/SB 4X4 6sp, camper puller
Tintacker
